What is a Banjo Bolt?
Old 11-26-2002, 03:01 PM
Think of a small banjo with a hollow bolt through the part where you pick it. The head of the bolt has a crush washer between it and the banjo part. There is another crush washer on the other side of the banjo. The remainder of the hollow bolt is threaded into a pipe or something where there is a fluid of some sort. The portion of the hollow bolt inside the banjo has radial holes that permit the fluid to flow into the banjo part. The banjo is connected to another tube, usually flexible, by a nipple. This is the part of the banjo where you change the notes by holding the strings to the instrument to shorten their length. The fluid goes up the handle or whatever you call it on a banjo. It is a way to tap into a fluid in a pipe or add another fluid to a pipe. The crush washers make the seal.
Old 11-26-2002, 04:12 PM
TOO MUCH TIME ON MY HANDS.
Is this correct?
[IMG]banjo nut 101.jpg[/IMG]
Old 11-26-2002, 05:26 PM
Sorry, need to figure out how to put image in here.
Old 11-26-2002, 05:28 PM
Last try before asking for help
Old 11-26-2002, 05:32 PM
Old 11-26-2002, 05:36 PM
Maybe as an atachment.
Old 11-26-2002, 05:47 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
To clarify, they are NOT the twistie thingies you tighten banjo strings with??? Sheees! Next you'll be telling me that fluted bevels aren't musical instruments, either.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 11-27-2002, 12:32 AM
I thought it was a pretty good description for 5 minutes work using its name as the theme.
'Pickin and Grinnin'
Old 11-27-2002, 02:55 AM
least common denominator
scottmandue's Avatar
Always wondered what the heck a banjo bolt was!
Thanks a bunch!
I don't know if you guys are goofing around but FWIW
The handle is call the neck, the twisty things are pegs that are in the head then the strings go over the nut. the little metal strips where you put you fingers are frets and the strings are held up at the back by the bridge.
Aint I just a fountain of useless knowledge!
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-27-2002, 06:52 AM
