Send a message via Skype™ to massive
Washer Tubes routing
I'm tackling another issue a previous owner has left me on my early 944.
For some reason they decided to re-route the washer lines from the bottle to the jets on the hood. To do this they removed the section of tube that runs along the front of the car.
Can anyone post a photo of where this tube feeds from the bottle near the headlight > along the front to the other headlight and up the side?
Regards
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 09-29-2015, 08:47 AM
Found what I was looking for
Seems the routing wasn't entirely wrong after all, although a previous owner has removed the one-way valves which I will need to replace.
Old 09-29-2015, 04:59 PM
For the record, I have three 944's that are totally 100% in working order - everything except for the windshield washers - that is.
I haven't been able to crack the code on them.
Old 09-30-2015, 01:12 PM
Can someone tell me what's meant to happen here? The diagram doesn't clearly show what happens to the connections on the T and L when they go into the cap, surely they don't attach to the same pipe inside the water bottle? Or should there be two pipes inside the water bottle?
Old 10-06-2015, 09:19 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
2 PIPES IN BOTTLE.
The cap is fragile, so treat it gently
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 10-07-2015, 05:16 AM
Originally Posted by petrolhead611 View Post
2 PIPES IN BOTTLE.
Thanks, are both pipes the same length? And do they both have part 12 attached to the end?
Old 10-07-2015, 05:19 AM
On mine, only 1 of the pipes has the filter fitted .Pipes are similar length
Old 10-08-2015, 04:03 AM
Originally Posted by massive View Post
...a previous owner has removed the one-way valves which I will need to replace.
If the one way valves are gummed up would it cause the system to loose prime?
... I have to run mine for a good minute before I get spray. Motor works and tubing is not clogged, what causes the long delay in getting spray?
Old 10-24-2015, 03:01 PM
Tags
washer jets , washer tubes
