West Central Ohio 45380
Differences in spindles
I lost my data sheet in the specs of the early vs late and turbo spindles. Can anyone point me in the right direction?
www.plyhammersparts.com |
Garage Helper
'86 Turbo spindles have the early offset (23mm) - 87 and up have the late offset (47mm ?)
Did this answer your question -OR?
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
That is a start. I still need the thickness difference between the ba and turbo
The early NA spindle is 20mm thick at the strut clamp.
I've fitted an early rebuildable NA strut on an '86 951 in order to use a variety of strut-inserts: KYB, Tokico, Bilstein, Koni HD, Koni Sport adjustables, Koni 8611 dual-adjustables. The lower round hole on strut should be elongated since the spacing is slightly different. Made a 2mm rectangular shim to fill the thickness difference in clamp. Make a square and round hole in shim for the spindle-clamp bolts. Also added coilover-sleeves and 400-lb springs while I was at it. Last edited by DannoXYZ; 10-30-2015 at 08:26 AM.. |
Thread Tools | |
Rate This Thread | |
