Porsche Crest climate control
okay i have a 944s 87 that im having problems with the control dont no if its short to ground or what but every time i put a new control it burns it and stops working if there is some 1 that has had the same problem can u tell me wat i can do to fix it i will post pic
Old 10-27-2015, 09:19 AM
You probably have a short in the AC compressor clutch. Try unplugging that when you install the climate control unit.
Also, the burned land on the climate control unit can be replaced with a length of wire by soldering it in.
Good luck, George Beuselinck
Old 10-27-2015, 01:29 PM
Also, the burned land on the cruise control unit can be replaced with a length of wire by soldering it in.
I dont under stand about the cruz control and would i have to remove plug with the the 5 studs
Old 10-27-2015, 06:18 PM
Sorry, I meant climate control unit.
Old 10-28-2015, 12:45 PM
Dose that mean i need a new compressor
Old 11-01-2015, 06:24 AM
You can replace the clutch without having to replace the compressor.
Old 11-01-2015, 06:25 PM
Ok thanks very much
Old 11-02-2015, 08:28 AM
