New oil pressure sender
I picked up an FAE oil pressure sender- nothing was wrong with mine, but it looked like it may leak a bit so I dropped one in the shopping cart.
I changed it out today- my oil pressure read 2.5 bar on a cold start, bounced with revs. I swapped the old one back in and it went up to 4.5 bar on startup and came down as the car warmed up- normal operation. I am left wondering now- is the oil pressure sender I am using reading high, or is the new one reading low? Seems pretty weird to me.
PCA - Florida Citrus Region |
I bought the same one with the same low pressure reading so I then purchased an oe and all is back to normal.
Thanks Kwikt, I am glad to hear it's probably just a crappy sender. I don't have any reason to doubt my oil pressure is good. I might buy a Lindsey Racing adapter and an analog gauge to verify the pressure though, just going forward.
Unless anyone has information on the contrary, I am going to compare the threaded end of the sender to one VW uses- a VDO oil pressure sender for a VW Beetle is half the cost.
I installed an FAE sender. It was fine for a couple hundred miles and then started to indicate 0 oil pressure. Replaced with OE unit which is VDO and works fine. Hard to believe that a part that simple can't be made cheaper than the VDO and still be reliable but it appears that is the case.
The threaded section for a VW VDO sender of similar type is much smaller, so it wouldnt work anyway.
