 Maintaining revs after cold start Currently have an inconvenient issue where the revs will drop and stall the car after a cold start. The car starts first time no problem in the morning and the revs idle around 700-800 rpm quite happily, I then reverse off the drive and go to put it in 1st but the revs will drop before I have a chance to move away and the car stalls. I then start the car again and drive away and the problem goes away until I do a cold start in the evening or the next day. |
 There is a component in the fuel injection system designed to prevent this problem, the ICV or idle control valve. A few things can cause ICV problems. 1. ICV missing, unplugged, or non-functional. 2. Idle air bypass screw out of adjustment. You can consult Clark's Garage for idle adjustment procedure. If all that checks out, I would next suspect the coolant temperature sensor. |
 I got the exact same thing happening. Definitely the ICV. Did not want to open or close when applying voltage to it, until I cycled it a few times. It was slow to operate..... I need a new one. Adjusted the idle via the screw when I resealed the throttle body last weekend. Now it idles great when it's warm. The ICV sometimes decides to start working again but usually I need to keep the throttle depressed so it won't stall out while idling till it warms up. |
 Early 944 doesn't have an ICV, it has an Auxilary Air Regulator and an Electric air Valve Guess I should check my own blog posts more often944 Foot To The Floor: Erratic Idle Problem Porsche 944 (Square Dash Model) |
| All times are GMT -8. The time now is 08:52 PM. |
