pr944may's Avatar
Question 944 Does Not Startii
Are DME and DME RELAY the same unit.
Where is the location of the DME relay
Which is the secuence of the timing sensors, wich wire with which sensor
Can recomend a good source or publication for parts number and/or simple electric diagram with details or info?
Have no experience with eletronic systems and the only reference manual at hand is the Haynes
This is my first 944 project, almost finish and now I am working in the electric area which is my weekest experience
Old 11-30-2002, 09:36 PM
AFJuvat's Avatar
Would be a big help if you said what year you are talking about.
that said, here are a few answers:
No, the DME relay and the DME are not the same. That said, the DME relay and the Fuel Pump relay ARE the same. If your car is an 83 - 85, the DME/Fuel Pump relay is seconf from left, top row.
in an 85+ it is the row closest to dirvers side fender, 2nd or 3rd from the rear.
In either case, the relay will say DME on it.
if your car is not cranking, try reversing the wires on the timing and ref sensors.
Haynes is a good start. Beyond that, there is the workshop manuals which include wiring diagrams
What issue are you having with your car?
Welcome to the group
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-30-2002, 10:02 PM
pr944may's Avatar
It is a 1984,944
New fuel pump, new fuel-DME Relay
Refurbish DME
new coil, rotor and dist. cap and spark plugs
install used in good condition Sensors, the old ones had the plug desintegrate to time- dont know sensors sequence if any
Car was siting for almost 2 years
engine turns, but there is no spark
electric wiring complete but some contacts corroed by the time
need to check continuity( which is the only thing I know in the electric field) between coil and DME.
Any recomendations will be apreciated.
Old 12-01-2002, 07:31 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
1st change your plug wires (it's not on the list of things you changed). If you have a multi meter, check your secondary side of the coil while someone turns the motor over. use the RPM funtion. If you have RPMs, then it's between your coil and your plugs. If you don't it's the other way.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-01-2002, 06:41 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
I'm puttin' $500.00 on Todwic, smells right to me....oh, how old is the fuel in the car?.. assuming that there is any.....
Frank B
My car is naughty
Old 12-01-2002, 07:08 PM
AFJuvat's Avatar
swap the position of the sensor wires.
AFJuvat
Old 12-01-2002, 07:14 PM
todwic's Avatar
AFJuvat
Oh yeah, try that.
'86 951
Old 12-01-2002, 07:16 PM
