Video: Replacing radial sealing ring and pilot bearing
Hi,
The video is part of a series of videos showing the replacement of the clutch including the necessary additional changes at the transaxle Porsche 944. This video gives you a step by step tutorial how to replace the pilot bearing and the radial sealing ring of the crankshaft at the rear side of the engine. http://www.youtube.com/watch?v=jk_hId3Dmiw The other videos of the series will follow soon. The video has a German soundtrack, but English subtitles are added to YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the frame. Enjoy it, Jürgen |
Eric
Thanks for posting. Looks like a lot of work to make the driver though.
I just used a pvc pipe and cap to drive in the seal. Worked ok. A pilot bearing puller will work without the hassell of having to use all those spacers.
Eric |
right, the puller is missing in my tool collection. I have to look for such a tool. Regards, Jürgen |
| Tags |
| bearing , radial , sealing |
