-   -   Question about fuel injectors (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/89510-question-about-fuel-injectors.html)
afx 12-03-2002 02:29 AM
I have a leaky fuel injector and I decided that I would replace it wil a new one. I have seen that there is an injector for the early 944's and a different one for the latter ones (85.5+). What is the difference between the two injectors?
AFJuvat 12-03-2002 02:59 AM
they are not interchangable.
mounting size is different, seals are different, voltage is different.
AFJuvat
afx 12-03-2002 03:36 AM
Thanks for the quick reply... guess my plan of saving $4 is foiled!
SoCal Driver 12-03-2002 01:55 PM
Voltage is different???
Then why does all the current for the injectors on all the 944's and 924S's and 951's and 968's come throught the same DME relay?
Possibly you are thinking of the flow rates????
(Yes, I'm at work!!!)
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
