Motor Mount died today... Easy job?
Ok..I already bought a set of Turbo solid mounts, they should be here in a few days. I either pay my mechanic $200 to do the job, or I set it up on jackstands in my cold garage during finals week. If it's not too bad and stressful, I'll do it. Otherwise..I do have the money...should I pay him to do it? Help me out here. If it was warm...I'd probably go for it. But something about 20 degree weather makes me a bit unmotivated
Yes the motor is in the front....
Old 12-03-2002, 11:25 PM
AFJuvat's Avatar
It isn't too difficult to do, yo do however need some way of supporting the engine from the top when you drop the crossmember.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-04-2002, 03:52 AM
Scott R's Avatar
The backyard way that I did mine did not involve dropping the crossmember.
I lifted the engine from the lift rings with my shop crane and roatated the mouns 180, then slipped them out.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-04-2002, 06:31 AM
Shepper's Avatar
It's not too bad. I lifted my engine by placing a 4x4 across the oil pan and jacking it up a little bit.
Then I loosend the crossmember enought to wiggle the old mounts out and the new mounts in.
Bolt it back together...
Done.
Oh yeah, you'll need new bolts for the top of the mount. I got lucky and found some at Home Depot.
Old 12-04-2002, 08:37 AM
SoCal Driver's Avatar
I concure with Shepper. Block up the pan and drop the x-member down a bit. Don't need to unbolt the a-arms but possibly the hangers for the sway bar.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-04-2002, 09:15 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
My motor mounts came with new bolts for the top. I didn't undo any hoses, as the haynes manual suggested. I jacked up the motor a hair and did one side at a time. Didn't undo the steering knuckle, I just took the bolt out of the A-arm, undid the crossmember (loosen the other side of the crossmember a bit) and swapped em.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-04-2002, 07:15 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
how did you notice that it was .. dead?. what were the symptoms?..
Frank B
My car is naughty
Old 12-05-2002, 12:11 PM
Usually the car will vibrate at idle.
Old 12-05-2002, 12:53 PM
If you can't stick your fingers between the oil pan and the crossmember from the front of the car -- the engine mounts are mostly dead.
Old 12-05-2002, 02:35 PM
It was always pretty rough till after 2000. Now at 2000 it gets even worse. I shift at 3000 or under now just to keep it from vibrating. I had it checked out as well by my Porsche mechanic, and he got the same idea. My turbo mounts will be in on the 9th, and from what i seems, I can do it myself. By chance will I need to remove the front wheels? (long story behind this question).
Old 12-05-2002, 02:46 PM
