-   -   Side markers, turn signals, rear lights not working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/896794-side-markers-turn-signals-rear-lights-not-working.html)
thekidd 12-31-2015 08:39 AM
I don't know what I did, but a few days ago they were all working, every light. But the other day I went out and my 2 front turn signals don't work, all side markers, and my drivers side rear lights don't work, but both rear turn signals work, along with the passenger side rear lighting works. I changed some bulbs, nothing, so I checked for power to the bulbs, nothing, so I checked if they were getting power to the fuses, nothing. Seems like the wiring diagram (electrics sheet #2), all of those lights go to the turn signal stalk, even the side markers. How do I test the turn signal switch? Hoping I will clean some grounds today to a fix, but what should else should I look at? Thanks guys.
thekidd 12-31-2015 03:42 PM
I got them all working now. One was a fuse, looked OK, but indeed was bad, some were just a bad connection or something, unconnected them plenty of times but the last one did the trick. But one problem is still there, ran out of sunlight and warmth to Finnish. But the front passenger side turn signal lights up, but doesn't blink as it should. I do belive that it worked a few weeks ago, but will have to clean the contacts at the bulb, and recline the grounding point again maybe. Thanks for reading. Happy new year to you and your family.
