todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
idle question
Is the DME the only means that an early '44 has to regulate idle after the warm up enrichment? When I turn my headlights on, the idle doesn't speed up any more, and when the fans come on, it pulls the motor down, more so than it used to. I had a bad injector, but I replaced that. any ideas?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 12-04-2002, 02:00 PM
Scott R's Avatar
I loose a little with my headlights on as well. Curious...
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-04-2002, 02:04 PM
todwic's Avatar
900 +/- 20. I'm afeared I have a burnt valve, cuz the miss hasn't gone away.
'86 951
Old 12-04-2002, 03:46 PM
Scott R's Avatar
Check your intake boot for leaks. Sounds exactly like what happened to me.
I replaced every darn thing under the hood, then one day I removed the intake boot and found that it had cracks on the underside. This would mess the AFM up and cause a miss.
After 20 or so years they dry up and crack, espically since its between the stationary air filter box, and the engine.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-04-2002, 04:05 PM
todwic's Avatar
I took everything off and cleaned it, I'll double check the boot, tho. tanks mon.
'86 951
Old 12-04-2002, 07:10 PM
The early cars do not have any form of active idle control other than a solenoid mounted at the rear of the air box that opens when the A/C is on.
What you are seeing is the alternator loading down as more current is being drawn by the electircal system. This loading in commonly reffered to as "Counter Electro-Motive Force," or CEMF, and is "felt" by the prime mover (in this case the engine) as an additional mechanical load.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 12-19-2002, 05:12 AM
