wheel bearing references, inner and outer
Can anyone provide me with them please for a 1986 944?
Greatly appreciated
MJ in Beirut
Old 01-11-2016, 03:20 AM
Our Host has the parts you need.
Inner Wheel Bearing 999-059-098-00-M296
Outer Wheel Bearing 999-059-065-00-M92
Rear Wheel Bearing 999-053-020-01-34
The Rear Wheel Bearing must be pressed off and on. The tool is listed below.
Bearing Removal/Insertion Tool Bearing Insertion/Removal Tool - $98.00 : ArnnWorx Specialty Tools
I hope this is what you need. If you go on YouTube there are several places that show how to remove the bearings.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 01-12-2016, 08:01 AM
Cheers,
Larry
Thanks Larry
Are you sure though that the outer wheel bearing ends in M92 ?
best
MJ in Beirut
Old 01-15-2016, 12:20 AM
Hi MJ, The last three digets are what Pelican puts as an add on for their parts. If you wish to order from Pelican or another parts dealer you can just put the regular stock number for the bearings. The bearing removal tool saves having to remove the entire trailing arm, taking it to a machine shop for them to R&R the bearing, and then you having to reinstall the trailing arm. I used it on my car and found it was well worth the money.
Cheers,
Larry
Old 01-15-2016, 10:31 PM
