-   -   It took a year, but finally it goes properly! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/898045-took-year-but-finally-goes-properly.html)
Kiwi944 01-10-2016 01:23 AM
My 944 has been driving my crazy with the normal 944 stutter and after almost a year of slowly replacing all the likely suspects with little or no change to the car's behaviour (AFM, reference sensors,temperature sensor, J-boot, spark plugs, fuel filter, ignition switch, and as soon as they arrive from the USA, distributor cap and rotor) it seems my 944 is cured!.
Like so many things on this car, it doesn't quite add up. It is an 82-build USA spec car, with a three-wire o2 sensor. I disconnected the double plug for the sensor (the third, single wire is still, at the moment, plugged in) and the car now runs perfectly! Not a hint of any surge or hesitation on any throttle setting or temperature.
As far as I can make out, this is not the correct o2 sensor for the car but hey, it now goes like it should so I'm not complaining!
J1NX3D 01-10-2016 03:05 AM
congrates man!! and you still have 2 months of summer left to enjoy it!
now drive it and get some photos!!
mytrplseven 01-10-2016 07:53 AM
Good on ya. I've been down the same road myself; replaced nearly everything and it came down to a faulty ECU (DME). Enjoy your toy in your beautiful country. I love it there.
Kiwi944 01-15-2016 07:52 PM
Yep, and it's great. Just driven it from Christchurch to Hampton Downs for Porsche festival. Fuel consumption is now amazing. Christchurch to Wanganui 7.6 litres per 100km or 37mpg (Imperial gallons) and the engine which always ran hot now sits right in the middle of the gauge.
All is happiness in my Porsche world right now!
J1NX3D 01-15-2016 08:19 PM
will you be there tomorrow? i'll be there between 11 and 3
Kiwi944 01-15-2016 10:10 PM
Yep, I'll be there all day. I'll PM you my mobile no. Text me and we will catch up
Cheers
Tony
