Power steering rack rebuild
I have been scouring the web and Pelican to identify two parts I can understand where they reside.
One is a thrust washer, the same as the two that reside on each side of the shuttle seal on the rack The other is a bronze washer with a bevel on one side, same ID as the thrust washer. I'm at wits end of all the online pics and procedures I've been looking at. Can anyone ID these for me and where they go? Thanks in advance!!!!!!!!!!
I only need time to get it back on the road..... right dear?....dear...dear? |
Proprietoristicly Refined
Have your seen Arnnworx?
944 Steering Rack Reseal : ArnnWorx Specialty Tools Any scratch on the polished shaft will cause a leak... J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Kessel run in 12 parsecs!
Zim's in dfw has a lot of parts for 944, give them a call!
Thanks guys,
Yes have seen Arnnworx and a number of others! FastFreddy, don't need parts just where these are suppose to be located in the assembly process. Would like to see a blown out diagram, but can't locate one.
Here is the Brass thrust washer with the bevel on one side
