exhaust system torque values : meaning of "+"
this is a "loose end' I've wanted to sort out for a while:
shop manual, vol 1, sec. 10, page 10-06 :
exhaust system: torque values - for example:
all other screws and nuts:
M6 8 + 2 (Nm)
question: what is the meaning of "+ 2" for the torque (in Nm)?
there's another page somewhere that has the same "+", but the idea is the same. It doesn't look like a torque angle - that'd be degrees. And when things are done in stages, it says so clearly with the word "1st stage" for example, with the oil pan bolts.
87 944 NA
Old 01-30-2016, 11:21 AM
It is an allowable range. At least 8Nm but up to 10.
Typically ranges are there to allow for cotter pin alignment. On the exhaust, it may be allowing for drag torque of self locking nuts.
Sent from my Chroma Nexus 6
Old 01-30-2016, 11:51 AM
interesting
87 944 NA
Old 01-30-2016, 11:53 AM
Toofah King Bad
Rasta Monsta's Avatar
Run everything up to 8, let it settle, go back and increase to 10.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-30-2016, 02:06 PM
@Rasta interesting - that makes sense - I don't think I've seen such notation for anything else.
87 944 NA
Old 01-30-2016, 02:21 PM
I don't think I've ever noticed that notation before either. Ya learn something every day. Make sense though..
Old 01-30-2016, 03:30 PM
I agree with Rasta. Run it to 8 then rerun it to 10.
Old 01-31-2016, 06:27 AM
Those are normally listed as a "series" or "order" vs being listed as 8 + 2.
Old 01-31-2016, 06:36 AM
