Finding tdc without a flywheel
I've just bought a 1988 2.5 8 valve second hand engine to drop into my car. Before fitting I want to change the belts and pulleys. The engine has had the clutch and flywheel removed by the shop I bought it from (making it ready to replace the rear main seal).
My question is how can I set the engine to top dead centre without the flywheel attached as I am not planning on taking the old engine out of the car until the new one is ready so don't have the parts to transfer.
Old 01-31-2016, 08:47 AM
West Central Ohio 45380
plyhammer's Avatar
Put a wood dowel in cylinder number one in the spark plug hole and crank it around until the dowel is at the highest point
www.plyhammersparts.com
Old 01-31-2016, 09:03 AM
Use Plyhammer's method plus the mark on the cam gear. But double check it when you get the flywheel back on.
Old 01-31-2016, 09:14 AM
Thanks very much to both of you.
Old 01-31-2016, 11:15 AM
It's best to measure for a particular piston depth before and after TDC and split that to find actual TDC. You'll find that the piston seems to hover at TDC for a few degrees since the piston speed relative to the crank RPM drops off so much near TDC and BDC.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 01-31-2016, 12:39 PM
