Going faster all the time
Oil Pan Gasket v. Removing the engine
So, I am at a crossroads I think...
I read through clark's garage on the oil pan removal procedure, and on the turbo... this seems like most of the same work to pull the engine, or at least a similar amount of time. Although my oil pan is leaking... I would love to do a front engine seal and redo the belts/waterpump as well. The leak(s) are significant and something I inherited from the PO. It's a consistent enough of a leak that there is NO way I could consider a DE day, or even an autocross, really until it's addressed. Does it make more sense to pull the engine (or drop it, actually, I guess) than to go through the exercise of the oil pan gasket replacement? Trying to formulate a fall/winter plan.
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
More Boost!
Doing the pan gasket on our 951's is not a nice job. If you start your shopping list now and have some patience, for $1200-1400 you will have a nice tight, dry car for the upcoming events you have planned, and for years to come if you do everything I have listed below.
Price is obviously dependant on what you are going to replace with the engine out. Clutch/Porsche Engine Mounts will take up $800-900 , otherwise it's a cheap reseal/tb/wp for $400-$600 If this is a winter project I would drop the engine, degrease the engine/engine bay, do the clutch, rms, rod bearings, Oil Cooler Reseal, AOS o-rings, balance shaft o-rings front/back, reseal the balance shaft covers, replace the heater control valve, replace all coolant hoses (18 hoses on the 951's I think), replace the dipstick o-ring, replace your motor mounts since it's literally at your fingertips,replace the crusty under intake hoses (venturi, isv), replace all of the vacuum lines and t's, and then do your FOES/WP/Timing belt/Cam Box reseal. Sounds like a ton of work, but with the engine out and not crammed into the engine bay, and placing the engine on a stand makes this task 1000x's easier than having to do the work with the 2.5L in the car. Cheapest price I have found: NEW 944 Turbo Water Pump $154 with gasket -- ZIMS AutoTechnikhttp://www.***********/store/new-water-pump-late-version-944t.html NEW 944 Timing belt Kit $180 ******* https://www.*******.com/products/porsche-timing-belt-and-tensioner-kit-944-fcp-porkit2?gclid=COWll43xsM4CFcEmhgodNoEKMw NEW 944/944T Deluxe Front Engine Seal Kit with steel races $116.50 ZIMS AutoTechnik NEW 944T Oil Cooler Reseal Kit $36 NEW 944 Engine Mounts x2(porsche,corteco) $185/ea @ sonnersporsche NEW Rod Bearing Set, Std., 924S/944/944T/S/S2/968/928 $86.60 ZIMS AutoTechnik http://www.***********/store/rod-bearing-set-std-924s-944-944t-s-s2-968-928.html New 944 Oil Pan Gasket $40 online everywhere NEW 944T Sachs Clutch Kit, clutch fork needle bearings $5-600 http://www.***********/store/clutch-kit-944t-86-91-turbo-cup.html NEW Hoses/Fittings/Vacuum Lines/O-Rings/Heater Control Valve/Misc. items/RMS $150-$200 Optional Upgrades: t3/t4 50/57 trim turbo 3" downpipe 3" full exhaust Tial WasteGate Last edited by fiily; 08-07-2016 at 08:58 PM.. |
Toofah King Bad
Just stood at these crossroads and decided to pull the engine for a complete reseal. I am confident that the time saved doing the work on the stand, as opposed to a tight engine bay, completely justified the R&R time, especially on a turbo.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thanks for the list fiily.
I have inspected my clutch and it's all good... just did the master, slave and connector line as well. To top it off, I already have the first 3 things on your list, plus the PO had all the "easy" vacuum lines done, so it's just the crusty ones under the intake I have to deal with (which has to come off anyway). The more I think about this, the more it seems like the easy (smart) way is to pull the engine. Now to find a stand...
plays with toy cars
Harbor freight, $40
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
More Boost!
Check your oil pickup tube for any cracks if doing the bearings. |
