-   -   Dynamat instead of carpet mat (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/903254-dynamat-instead-carpet-mat.html)
WOLVERINE 02-20-2016 07:02 PM
Has anyone ever replaced complete 944 carpet matting with a DYNAMAT type product in the ENTIRE interior?
Arizona_928 02-20-2016 09:35 PM
Yes. Very common. The car is not that loud though, and you do gain weight.
Good luck removing the hard rubbery sticky stuff. It sucks
v2rocket_aka944 02-21-2016 09:15 AM
Very, very expensive, and it doesn't really work that well. Also very heavy, as noted.
I ripped out all the old carpet, padding, and rubber/asphalt type insulation mat and replaced everything with 1/2" jute pad and lightweight felt-style carpet.
The carpet for the whole car weighs about 9 lbs, and the jute is probably another 15-20.
And the interior noise level really isn't all that different.
WOLVERINE 02-21-2016 11:31 AM
any pics of process?
v2rocket_aka944 02-21-2016 12:02 PM
Not really.
Just lay stuff in place and cut til it fits...
Rupert944 02-21-2016 10:08 PM
944 sound deadening is actually pretty good for the weight, IMO. If you do want to go nuts and don't mind some weight gain, do a bit of research on the best strategy for sound deadening in cars in general (it's not dynamat everything).
sausagehacker 02-23-2016 06:38 AM
I removed all of mine and replaced it with Frost King duct insulation. I think it was under $50 for the whole car and weighs a lot less. Didn't notice substantial noise difference, main motivation was that my old sound deadening was moldy and waterlogged and falling apart in chunks.
v2rocket_aka944 02-23-2016 07:18 AM
LOL I did the same thing ^^^
flash968 02-23-2016 07:29 AM
i find these cars to be incredibly noisy. i ended up installing dynamat extreme on all outer surfaces, and dynapad on the large flat horizontal surfaces, on top of dynamat extreme. the result was an incredible improvement in stereo sound quality, and a much improved overall ride experience. total weight gain was about 50lbs. big deal.
dgcantrell 02-23-2016 08:10 AM
I've noticed that a lot of restoration shops are now using the spray-on truck bed lining for sound deadening and undercoating. Sounds like a great idea to me.
ckelly78z 02-23-2016 08:47 AM
I used the 75 sq.ft. box of GT-Mat, which is very similar to Dynamat, but actually thicker at 110 mil, compared to 80 mil for dynamat, and cheaper at $175, compared to $350 for the Dynamat extreme bulk pak. This 75 sq ft box did the entire car and inside the doors. I then put the stock good shape carpet back on top of it. I'm really pleased with the tightness and sound of the stereo now. I would reccomend doing it while the garage is warm....much more plyable and easy to work with.
