Amatuer Hour Specialist
Wellwood's Avatar
A simple suspension question (like there is such a thing, right?)
So...I've got this 968 Turbo Project that is finally looking like it is going to finish up. As the cars suspension components are bone stock, I've figured out I want to do something about while I still can.
To that - I've upgraded the sway bar assemblies to the 968 M030 sized components and sourced a pair of the front springs from the 968 Club Sport. Figured I'd stick in a set of Koni Sport Struts to finish off the front. For the rears - thought I'd go with the Koni Sport Rears, but then I got a hold of a set of M030 springs and the associated washer. To complete the rear I'm faced with the dilemma of either sourcing rear M030 shocks - or a suitable replacement if I want to use the helper springs.
So...the question is there a suitable replacement shock that can be used with the M030 Spring/washer assembly?
TIA-
Old 04-08-2016, 07:21 PM
More Boost!
Jay, you can always go with koni 30 series rear coilovers from Ground Control, then reduce the cost of buying that set for $650 by selling the m030 rear spring/washer assembly that you currently have.
My $.02
Old 04-08-2016, 07:29 PM
Wellwood's Avatar
Thanks for the suggestion filly.
Old 04-08-2016, 07:59 PM
