Clonking
how come I get a clonk clonk when slowly reversing on full lock? The rack is not that old. It sounds like something is moving then going back.
944s2
Old 03-15-2016, 02:22 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Take a look at the steering rack mount for looseness and tie rod ends, ball joints and also control arm bushings for movement. Are wheels all tight?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-15-2016, 03:36 PM
944tothefloor's Avatar
You'll want to do what mytrplseven said. lift up the car so you can see if the wheels will wiggle in any direction. I would guess ball joint at this point.
Old 03-15-2016, 03:47 PM
Thanks for your replies, will be checking again for that noise, and possibilities mentioned, I think I can find a place that would let me use their lift.
944s2
Old 03-16-2016, 01:48 AM
You don't need a lift, just a jack and a couple stands. Now, a lift will be easier, but if you *have* the jack, I'd start there.
Old 03-16-2016, 09:15 AM
