944S2 Field Repair Kit
Autocross this weekend.....4 hrs away. I want to prepare accordingly for a 28yr old car. This is what I have currently, what am I missing?
PCA track inspection--Check
Oil newish and topped off--Check
Brake Fluid--Bled recently and topped off
Coolant--topped off
Toolbox:
Torque Wrench
Adjustable wrench
Stubby flathead
Phillips
8mm-19mm combo wrenches
Channel locks
Needlenose with integrated dykes
Vise-grips
Low gage insulated wire
zip ties
electrical tape
Auxiliary fan relay
White lithium grease
Thanks in advance!
Old 07-11-2017, 04:09 PM
In the Fires of Hell.....
kdjones2000's Avatar
Credit Card....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-11-2017, 04:13 PM
Picture of my ignition switch....
Old 07-11-2017, 04:43 PM
rubber mallet...very useful in the event of an "unexpectedly overtight bolt" that you may need to remove.
750mL bourbon...
handgun.
Old 07-11-2017, 04:56 PM
You could add a set of sockets and a ratchet, since you have a torque wrench, plus an assortment of extensions. Also a spark plug socket, and a multimeter or a test light. I guess you will be using the tire changing jack and lug wrench to get the car up a little, do you want to add a jack stand or two or some blocks? Make the adjustable wrench a big one in the case of a suspension component.
And then for spare parts...
Old 07-11-2017, 05:08 PM
Politically Incorrect
onZedge's Avatar
I just noticed that the only mathematical key on your "ignition switch" is the multiplication function.
Funny.
Edek
'87 924S
'91 535i
Old 07-11-2017, 06:33 PM
VOM.
a spare dme relay or male spades if your wire is suitable for the fuel pump current.
tire patch kit (assuming you roll with a portable compressor on trips)
spare quart or two as most things can use oil at 6000 rpm.
Old 07-11-2017, 07:42 PM
Duct tape and tie wire.
Good luck, George Beuselinck
Old 07-11-2017, 09:53 PM
jhowell371's Avatar
In addition to what has been mentioned a gallon of extra coolant, jumper cables and of course the most important thing, your AAA card for the flatbed trip home if needed.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 07-12-2017, 04:37 AM
Originally Posted by v2rocket_aka944 View Post
750mL bourbon...
Much like the Credit Card....makes all other tools moot
Old 07-12-2017, 05:02 AM
