Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
db9146's Avatar
Looking for 951 Service Recommendation in Atlanta, GA
Hi,
I've got a low mileage 944T in which I need to have the rollers. belts, and water pump replaced because of age. I fired the shop that had been maintaining it for me when they screwed me over on a clutch replacement.
Anyone have any firsthand knowledge of a good shop in Atlanta (preferably NE) that you would recommend for this?
Old 03-27-2016, 05:06 PM
Turbonut
Raceboy's Avatar
You can contact manu4jc, his garage is located in MacArthur Blvd, should be close enough.
'83 924 2.5 16v Turbo, 530hp @ 1.5bar
'67 911 widebody hot-rod /2.4S
http://www.facebook.com/vemsporsche
Old 03-27-2016, 08:43 PM
BlueStwo
Phantoms's Avatar
When I lived there I had mine done at European Motor Cars. Kinda pricey but they did a great job. They have a few locations in the area.
90 S2 Coupe- Baltic Blue Metallic #110/449
Old 03-28-2016, 03:03 AM
JoshB's Avatar
Motorwerks Racing in Cumming or Kerry Singley at Autoworks.
91 944 S2 white/blk
86 951 gray/blk
Old 03-28-2016, 05:36 AM
I used European Import Specialists for a PPI on my S2. Seemed knowledgeable about the model, were accommodating to my schedule, good communication, and I felt treated fairly. In Marietta.
Old 03-28-2016, 08:06 AM
db9146's Avatar
I'm checking out all the suggestions - thanks.
Old 03-28-2016, 10:12 AM
+1 on Manu4jc. And I think he has a location in Marrietta now.
Old 03-28-2016, 03:53 PM
German Car Repair in Alpharetta is legit, and not too far from you. Definitely worth checking out. They replaced my fuel lines and installed new tie rods for me. Top notch work, head mechanic is a German guy that used to work for Porsche in the motherland.
German Car Repair
Old 05-28-2016, 07:28 PM
drift a 944's Avatar
I may be a little farther being in Athens but I have 944 customers come from the far side of Atlanta for service. I charge 250 to 300 tops on labor for a 951 water pump and timing belt job (depending if you want front seals done too, etc.), better than any shop will charge for labor. If you're interested just send me a PM and we can go over more details.
-Elliott
- Elliott
1986 944 orange (supercharged drift pig!)
1986 951 black (the green goblin! / drift pig 2.0)
1986 951 camo (drift pig 3.0)
1983 944 green (the bean! / daily driver)
Old 06-03-2016, 03:54 AM
911lnv87's Avatar
Hi Guys, I might be moving to Atlanta area and I have an 86 951 2.8L strocker with a cat delete, so a straight pipe how is inspection in GA?
thank you
Porsche 944 Turbo - Graphite Metallic - 2.8L - 1986 DD
Porsche 944 n/a - Dark Blue - 1988 - Sold
Old 06-03-2016, 04:36 AM
thank you
It depends on what county you live in - not all require emissions- I'm pretty sure that you will be exempt because the car is over 25 years old.
Old 06-03-2016, 07:54 AM
Amatuer Hour Specialist
Wellwood's Avatar
Yep. 25 years is the magic time.
Old 06-03-2016, 08:01 AM
+1, No emissions in GA for cars over 25 years old!
Old 06-08-2016, 10:45 AM
Tags
944t , 951 , technicians
