West Central Ohio 45380
Coolant puke question
Any thoughts on a coolant puking with the temperature still reading good via the temp guage?
www.plyhammersparts.com |
Head gasket or coolant tank cap, generally.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
In the Fires of Hell.....
Coolant cap has been the issue for me in the past.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Did that cause the coolant puking?? Easy enough to check
Banned
In my experience the coolant cap causes puking after shutdown but normal behavior when just driving around. A head gasket leak will constantly push coolant out of the system when running and eventual overheat.
This was sitting at idle for 15 minutes burning off the excess oil on the headers from the cam tower gasket change
+1 on coolant tank cap... Cheap enough to fix, or free to check the cap opening pressure with a loaner tool from Autozone.
Good luck, George Beuselinck |
I had a loose lower radiator hose clamp. Simple mistake I know... but something easily overlooked! It took me a while to realize why I was puking coolant when everything else seemed ok. Just Sayin' Andy.
1974 911 1978 911 1980 924 1987 944 |
Thanks all. That gives me enough to check!!
When you say puke, do you mean:
A. The coolant looks a puke like colour? or B. Do you mean the coolant is puking (as in pumping or backing up) out of the coolant tank? If it is B, then it could be a seized/seizing water pump
1984 944, 2.5L, manual transmission, UK right hand drive. http://944foot2thefloor.blogspot.com/ |
He means it losing coolant somewhere.
It is s violent puking out of the reservoir
www.plyhammersparts.com Last edited by plyhammer; 03-29-2016 at 12:42 PM.. |
Ohhh. violent puking is not a good sign. Does it start as soon as you crank the engine?
Nope starts after fifteen minutes. I probably didn't bleed it well as I had the hose to the gooseneck off when doing the cam gasket job. Water pump is turning. after fifteen minutes the top hose was nice and hot and the thermostat hadn't opened yet. I have a butch of new thermostats so will let it cool off and swap in a new Tstat and rebleed.
I have what I think is a stuck thermostat based on the gauge reading, and it didn't loose a drop of coolant. In your case I wonder if there might be a clog between the coolant tank and the radiator? Is it bled properly?
Toofah King Bad
Don't overfill... observe the MIN line when cold.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
might be leaking compression into the coolant system.
dolor et pavor Copyright |
