'86 951 - almost stock
1986 944 Turbo clutch pedal hangup at top
Hello to all, car drives shifts fine but when I let the clutch out, at the very top of the travel sometimes it stops with an inch to go, & then i flip it up with my foot and she springs all the way up(last inch or so) - i would like to think it should be smooth the whole way- any takers appreciated - Respectfully, NickyRicky
Probably just an adjustment needed on the rod that connects the pedal to the clutch master cylinder under the dash.. It probably has just a little too much slack in it.
failing hydraulics... clutch massa, and slave
85 928S; LSx conversion, 5 speed with LSD. ![]() ![]() IRR... What IRR! ![]() Last edited by Arizona_928; 04-16-2016 at 11:42 PM.. |
I have this issue on my 84 sometimes. Check the brake fluid level and see if it might be a little low. After I top up it returns to how it should be after some pumping.
1984 Porsche 944 1986 Porsche 944 Turbo |
Thread Tools | |
Rate This Thread | |
