Fuel filters tips, removal
Dear All
I want to change the fuel filter on the 944 (1986) and wanted to ask if anyone had tips. Curious to know if it would help to remove the rear, right side wheel to get better access
thanks
MJ in Beirut
Old 04-27-2016, 01:51 AM
Staubsauger!'s Avatar
no but it is easier
loosing the fittings while it's still in the mount. then undo the mount before taking the hoses off. very easy
Die Kirche im Dorf lassen
Old 04-27-2016, 02:20 AM
A day or so before you start this job, spray some PB Blaster or some other penetrating oil on the connections and let it soak. The fuel filter being located where it is a magnet for crud which will cause corrosion on the fittings. Letting the penetrating oil sit and do it's job for a day or so will make it a lot easier.
Old 04-27-2016, 05:30 AM
Misunderstood User
This is a must - I would not use an adjustable wrench on the fittings either ( it is fine for the filter)
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 04-27-2016, 06:33 AM
This. So many times over.
Old 04-29-2016, 06:49 AM
Patrick
pfarah's Avatar
Can't I just use a torch to heat the fittings...?.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 04-29-2016, 12:53 PM
There's a thought, but probably not a very good idea!
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 04-29-2016, 01:26 PM
944 S2
944 S2's Avatar
Maybe dumb question but doesn't gas drain out everywhere when you disconnect the fuel line or is the pressure held back?
Old 04-29-2016, 03:00 PM
Administrator
Luccia at Pelican Parts's Avatar
When it comes time to do the job you can use our fuel filter guide HERE for some help. Figure 2 goes over some info on how to get some of the fuel out of the lines before the removal of it.
Filter if needed - 1986 Porsche 944 Base Coupe - Fuel System - Page 1
Old 04-29-2016, 03:09 PM
Yes, it will be pressurized. But just keep a drain pan handy and crack the fitting open just a little to let the pressure bleed off and catch the gas in a pan. Regardless of how you do it, it's messy..
Old 04-29-2016, 03:10 PM
You can also start the car, then pull the fuel pump fuse and let it run
until it stalls to relieve some of the fuel line pressure.
Old 05-02-2016, 01:39 PM
Reverse steps
I pull the fuel pump fuse first, then crank the engine. Less fireworks.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 05-02-2016, 02:15 PM
