18" wheel fitment??
I know people telling me that i need et63 11" wheels to fit in the rear, but that fitment does not satisfy me, can i fit 11" et52 in the rear? Car is lowered and the 18x10 wheels i have right now have et58 with 14mm spacers, and i could go little bit more out
Fronts are 8.5" with et52 and 7mm spacers so im thinking 9.5" with et48 front is on m030 with 3" id spring
Old 05-19-2016, 07:46 AM
Interesting - I have Keskin Kt2 (9.5x18 ET52) wheels with 285/30 tires and the car (87 951) is lowered and the rear is rubbing pretty much. With 265/35 it would be fine. 18x10 ET58 wheels with 14 mm spacers are around 14.3mm outwards compared to my setup. Although the profiles of various manufacturers tires are not the same even in case the size is the same. What size of tires are you running? And is it late or early offset car?
Old 05-19-2016, 11:00 AM
Late offset car runing 275/35/18 no rubbing
Old 05-19-2016, 11:56 AM
Depends upon model & tyre size. You have Turbo or TurboS? If you want to stick with 275/35-18 on 11" wheels, then 52mm offset is fine. But if you want to run 295/30-18, then you gotta have more offset around 63-65mm like TurboS.
Old 05-19-2016, 05:53 PM
