what is it, how hard is it to do, what gains are there?
Lon, Im Clueless, Elliott 1987 944 turbo Guards Red http://committed.to/speed the home page is a work in progress |
It's not hard to do. But it's easy to break off studs performing the operation.
When you install the shimm, it spaces the wastegate valve farther from the flange. It basically tricks the gate out. It's good if you have a weak wastegate. But for the money invest in the dual port wastegate from Lindsey.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
It is an old school way of raising boost. There are much easier, better ways to raise the boost now. Also, you do not want to raise the boost w/out a set of performance chips anyway, and they usually come with their own method of raising boost.
84 944(sold) 85 944 86 951 87 944(sold) 87 951 88 951 Turn up the BOOST!!! |
thanks guys
how high can i safely put the boost on a stock 87 951
Get the GURU kit. Comes with FPR, chips and a "Reliaboost" controller.
It also has the shims ahould you have a weak wastegate spring. http://www.gururacing.net/ChipUpgrade.html
will 15 psi of boost hurt my stock 951 or can it handle it, i have a widfire head gasket..
You should be ok, I run 14 no problem.
even though you boost the psi only 4 or 5 do you actually get HP gains
Yes, depending on where in the power band its available.
how do you know or determine or set where it is in the power band.
