944 turbo bellhousing grounds question
yes another ground thread. I was cleaning my main grounds on bellhousing, i have the main battery ground and one of the smaller ones both grounded to the smaller location on the bellhousing, the stud where the the main ground is supposed to go has nothing. isnt there supposed to be 3 wires? if so I guess I can have fun and pull my intake for the 5th time and try to find where my missing ground is. someone tell me that sometimes there are only 2 ground wires in that location but I doubt that's the case.
ok i found my missing ground wire it was shoved into a wire loom strap. ok so does anyone know off the top of their head if the bigger of the 2 smaller ground wires is for the DME or the sensors? i bet this will make it run better if its actually screwed down.
