Wheel question, cross post from RL
I am thinking switching from 15" wheels to 17", more choices for tires. I have an '83, early offset manual steering. What wheel options are there for early offset? I would prefer to not have to use spacers.
If I do go to a larger wheel are there changes that I would need to make. And how would it effect my car? |
There are no factory 17" wheels with early 23.3mm offset. Aftermarket ones are available but they are heavy monsters. Nothing wrong with spacers if you get the non-adapter types and install longer studs. In fact, this is how the factory did it on the rear.
If you get heavier than-stock wheels & tyres, handling and ride-quality will suffer. Main benefit is improved cornering grip. On my '86 951 (early offset), I was able to use 17x10.5/11.5" wheels with 255/40-17 and 275/40-17 tyres by increasing offset by 1/2" to 35mm. Similar to what Porsche did in going from Turbo to TurboS. |
You're gonna have to do some researching on custom wheels, as the backspacing will be different than stock. If you use a larger, wider wheel, chances are you'll need spacers. These links might help you.
944 Wheels FAQ 14.0 Performance Modifications I personally love the cookie cutters, but couldnt stand the wheel gap in the rear. So, what I did was swap out my studs for longer ones, with the factory spacer and a second hubcentric spacer. Open ended lug nuts too. Ive read not to go any larger than 17" wheels on a N/A 944 because it'll affect peformance. |
Search a u t o m o t i o n . c o m for "Euromeister." They may not be feather light, like the originals, but I've seen them on a few cars and they look fantastic. They do come in 17, and the price is right.
Nice look, are they available in a late offset?
| All times are GMT -8. The time now is 11:48 PM. |
