944: Sauna edition
Hi there. I have a 87 944. Heat is on all the time. The controls seem to work in that if they are set to heat, it gets hotter. But, it never turns off. Its going to be over a hundred here soon, and I won't be able to stand it if I can't fix it! Any ideas?
Thanks!
Old 05-29-2016, 08:33 PM
944 S2
944 S2's Avatar
I'm no expert, but I believe Clarks Garage cover this kind of common problem.
Clark's Garage Home Page
Old 05-29-2016, 08:53 PM
Just above the gas pedal under the dash, there is a control box for the climate control flap. There is a rod connected to a lever on that control box. The clip that holds it onto the lever is broken. When that happens the flap stays on heat mode all the time. The clip can be had from here at Pelican or any other online source. It's a cheap fix.
Old 05-30-2016, 06:50 AM
Toofah King Bad
Rasta Monsta's Avatar
You might also check the vacuum line to the heater valve. If it is leaky or broken, the valve will "default" to heat on.
» 1987 924S - Pro44 Race Car • 1987 924S - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-30-2016, 08:29 AM
had similar issue and this fixed it:
944 Heater Fix
1990 Porsche 944 S2 - RoW car - Sold
2001 Porsche 911 Carrera 4
Old 05-31-2016, 01:38 PM
Have 944, will restore
mazdaverx7's Avatar
I have also had the same issue and it was caused by the plastic clip breaking and the control arm falling out of place. Make sure you order the plastic and the metal clips. I ordered my parts here at Pelican. Just give them the part numbers and they'll get the parts headed your way. And you'd be surprised, the parts are really cheap.
85.5 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3/ 18 Camry SE
Old 06-01-2016, 03:33 AM
2002M3Drew's Avatar
Send a message via AIM to 2002M3Drew
LOL on the thread topic!
1983 911SC Coupe
1985 928S
1987 944 Coupe
1992 Carrera C2 Coupe
2006 Cayenne S
Old 06-01-2016, 10:59 AM
Send a message via AIM to MPitt
Just want to +1 Jordanarendt's Heater Fix link. I have this issue intermittently in my turbo. Once you get down and see the heater control arm it's easy to put back in place.
1984 Porsche 944
1986 Porsche 944 Turbo
Old 06-09-2016, 01:52 PM
Yep...Cheapest part I ever bought for my 944 was that little plastic clip. Dealer part too !!!
Old 06-09-2016, 04:11 PM
rickharrison's Avatar
Just repaired mine today...damn its hard to get down under there...easy-peasy.
Almost had to call my wife to pull me up! lol
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 06-11-2016, 08:34 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
