Dead cylinders
I have an S2 with the middle two cylinders not firing. Weird thing is the injectors are getting signal. I even swapped them out and still no luck. Plugs are sparking. Leak down is good on all cylinders and compression is 220 across the board.
Anyone have an idea? |
Did you try swapping the plugs. One thing I have found out is that a spark travels 10 times less distance under the compression of a cylinder than it does in the air if you pull a plug to test it.
1987 944 Summer 2006 E90 Winter |
tap the fuel injectors.... they may be sticking.
85 928S; LSx conversion, 5 speed with LSD. ![]() ![]() IRR... What IRR! ![]() |
I replaced the two injectors, not much of a chance of 4 bad ones. The two I swapped out came from a car that a friend just parted out 2 months ago and was running fine
Did you noid light the harness?
Frankly my dear....
Have you checked the ballast resistor pack connectors? A bad connection there could give rise to the injectors not working correctly - only the 16V engines had these I believe...
The pack is located under a plate on what would be the passenger side inner wing (fender) panel. A large aluminium pack with a round connector - mostly overlooked by people as it is pretty well hidden, but always worth a check.
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Need more info.
Does the car run? when did the car last run? Does it run on 1&4 cyls? How have you confirm this? How is the speed and reference sensor gap? The wiring/connectors/sensor condition? possible arching? I have worked on cars that have warped the flywheel, and would cause problems like this. My best guess: speed sensor reference sensor DME engine grounds
First, actually confirm real fuel VOLUME. Pull the rail, put little cups under each injector and crank for 10-seconds. Compare fuel-volume in each cup.
Then measure resistance of each plug wire. Take a look inside distributor cap & rotor. I've seen brand-new caps that were strangely ovalized so two of the cylinders were getting weak spark. |
looks like it may be the ballast resistor
Thread Tools | |
Rate This Thread | |
