rickharrison's Avatar
clicking
I get a clicking from the passenger footwell...is that the cabin temperature sensor, or maybe the DME?
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 06-03-2016, 04:43 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
It's possible that the cruise control motor (forward of the battery) could be cycling. Pull the plug on it to see if it stops.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-03-2016, 05:57 AM
Yep.. Mine started that crap. I had to unplug the cruise control motor to shut it up..
Old 06-03-2016, 08:27 AM
More Boost!
I get the clicking down by the passenger footwell also, it clicks repeatedly sometimes 15-20x's.
Is this the same issue?To disable it, just unplug the cruise control module under the hood as mytrpl has mentioned, correct?
Old 06-03-2016, 01:41 PM
Yep.. That's all there is to it.. When mine was doing it, it took me a while to locate it. Being right there on the wheel hump in front of the battery, the sound would carry downward and make it sound like it was coming from inside the car. One day, I was working on it, doing and oil change or something. I got in to fire the car up and had the hood up. It started that clicking crap when I was standing right over next to it. Ah HA!!!! I FOUND YOU, YOU LITTLE CLICKING BASTARD!!!!! Unplugged it. I'll need a new control module as I think it is what is making it do the clicking thing.
Old 06-03-2016, 03:42 PM
I don't have cruise...
Rick Harrison
1988 944S
MaxHP chipped
Old 06-04-2016, 02:31 AM
944 addict
aaahahaha. Of course you don't. that would be too easy. Does it do it when moving or not moving?
Old 06-04-2016, 05:50 PM
Could it be the atmospheric pressure sensor that is with the DME? I believe it just riches the mixture above 5,000ft.
1987 944 Summer
2006 E90 Winter
Old 06-04-2016, 05:55 PM
That Guy
Techno Duck's Avatar
It is more than likely the solenoids for the automatic climate control. Move the temperature knob a little off full cold or full hot and see if it stops or gets worse.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-04-2016, 07:55 PM
I'll check that out. Right now the knob is full cold since we've had 28C weather here. Thank you sir!
Rick Harrison
1988 944S
MaxHP chipped
Old 06-05-2016, 06:52 AM
No cruise control? I thought that was standard equipment on almost all later 944's.. Hope you get it sorted out.
Old 06-05-2016, 07:48 AM
Arizona_928's Avatar
+1 on the early cars it has random hvac relays under there.
dolor et pavor
Copyright
Old 06-06-2016, 03:08 AM
Hmmm...did the heater clip repair, and no more clicking.
I wonder if the auto climate control solonoid was confused since the knob was off, yet the flapper door was in the full heat (fail) position?
Rick Harrison
1988 944S
MaxHP chipped
Old 06-16-2016, 04:20 AM
