James Chimney
K&N cold air intake
I used a K&N RC-5052AR cold air intake and K&N 85-6001 adapter and re used the Gromit from the OEM air box snorkel where it goes into the fender well, PO just had an exposed filter in the engine bay, I have the OEM air box but like the room under the hood. More photos available, as it does sit a bit of an angle[IMG][/IMG]
[IMG][/IMG]
Old 06-09-2016, 04:48 AM
911tracker85's Avatar
hate to be debbie downer, but I have reverted all of my cars to stock paper air filters. even on the 450hp build I am doing for my 930.
kept seeing comments and did some research. unless you have some monster motor build that needs huge amounts of air, the K&N does not really improve performance.
and from a couple engine builders, they say they can tell if an engine had a K&N by the fine scouring of the cyl walls as K&N can allow fine dirt/dust to get by.
YMMV
but good work on what you did.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 06-09-2016, 06:15 AM
flash968's Avatar
i've dyno tested a few K&N filters on a different cars, and they all showed power increases. on the 968, it made about 5hp. it is critical though that the filter be separated from the hot engine bay air in order to get that increase.
as for dirt getting in, if the filter is PROPERLY oiled, it works just fine. if it is dry, dirt gets in. most people don't take care of the filter. it has to be regularly cleaned and oiled.
no free lunch
Old 06-09-2016, 07:18 AM
Toofah King Bad
Rasta Monsta's Avatar
Interesting, that is the first aftermarket intake I have seen for a 944 that actually makes the effort to get cold air.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-09-2016, 08:09 AM
When developing the "NA-tune" plug-and-play MAF kit for the 944, Rogue_Ant did back to back testing with a standard paper filter, a K&N filter, and no filter at all installed in the 944 air box...absolutely no power difference.
So on a 944 setup it doesn't do anything...but a 968 is a whole nother story.
no free lunch
Old 06-09-2016, 08:23 AM
When I ran the ROGUE MAF kit I logged intake air temps with a cone filter in place of the airbox, and then relocated over in the fender hole...
IAT only climbs when sitting still. As soon as the car gets moving the IAT is ambient within a few seconds.
Old 06-09-2016, 08:25 AM
What kind of K&N cold intake is that? did you make it? part numbers please? Some people say the stock box is more than enough some people just like looking at aftermarket parts in the engine bay. I would like to at least try out this K&N filter that is under that hard plastic casing going directly to the fender. I think this would produce some cold air or at least shield it from hot air.
Old 06-09-2016, 09:24 AM
Sorry about that, didn't notice you posted the part numbers at the top of your post. Thanks.
Old 06-09-2016, 09:29 AM
flash968's Avatar
one of the key issues with any cold air intake and its ability to add power, is to ensure that the surface area of the filter is AT LEAST as large as stock. that filter in the first pic is almost certainly smaller than stock, and likely costs power. in the case of the 968, they make a direct fit filter, so it was easy to test and verify the increases.
i have seen even larger increases in my 06 yukon and 98 grand cherokee. other cars were easy to feel the difference, but i didn't test all of them. i've been running them on every car i set up forever, and would not think twice about it. it's almost the first thing i do, because it works, and in over 30 years, i have never seen any down side, when properly maintained and installed.
again though, the application is critical.
Old 06-09-2016, 03:59 PM
Sounds like a "total flow area" question then?
If the filter is big enough then the substrate may not matter so much (like the 944NA has a big filter).
But if filter size is limited by packaging, then a higher-flowing filter should let the engine breathe better.
I wonder if 944S2 K&N is worth anything...those things have a HUUUUGE filter.
Old 06-09-2016, 05:20 PM
James Chimney
KEEP in mind this set up is very tight, and I had to sand/grind the outlet of the K&N to sit a bit of an angle to get it to fit between the Coolant tank and Headlight arms. I have the original air box but I like having all that extra space in the bay (It looks nice too with the K&N) I have other photos of the install if needed. will post about how it feels to drive it soon.
Old 06-10-2016, 01:44 AM
flash968's Avatar
it is indeed a flow issue. we tested that with a manometer. it was not at all difficult to see the results. i actually had a magazine article published about it.
Old 06-10-2016, 06:33 AM
What magazine? When?
Can you provide a pdf of the article?
Good luck, George Beuselinck
Old 06-10-2016, 07:12 AM
plays with toy cars
sausagehacker's Avatar
I'd be very interested in seeing a test of the static pressure upstream versus downstream of an AFM (or any other intake component) across a variety of load/RPM sites. Would give an objective look about how much flow velocity is lost due to that component.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 06-10-2016, 07:34 AM
You've got a MAP sensor, don't you?
Old 06-10-2016, 07:42 AM
Going faster all the time
Litesonic's Avatar
It looks awesome.
I have been a fan of K&N filters for decades... and have definitely seen the benefits on many cars. I am really impressed by how contained it looks.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 06-10-2016, 07:58 AM
plays with toy cars
That little guy has to be behind the throttle body
I'm ordering a 2nd Megasquirt for the 951, and I actually think that would be a cool test I could do with it in "observation mode" while my NA is running.
Old 06-10-2016, 08:00 AM
flash968's Avatar
the article was in 9 magazine. it was about 10 years ago.
Old 06-10-2016, 08:41 AM
Leave it where it is, but log your MAP as you drive now, and then log MAP with an AFM installed "dummy" in the intake tract.
You'll see a pressure drop.
This is the same way I intend to test my VEMS with and without the AFM in the tract for power output...I should be able to do a MAP log too.
Old 06-10-2016, 08:42 AM
plays with toy cars
Makes sense, it stands in the way of the manifold equalizing to atmospheric. I have a bad AFM I could drill into to make some test ports as well.... Bernoullis law would make it possible to calculate the exact flow loss due to it.
(sorry for OT)
Old 06-10-2016, 08:49 AM
