944 race car fuel starvation right turns
944s race car sputters when fuel goes below half a tank -after hard right turn when full throttle is applied. I have read posts that the in-tank strainer/screen can be the problem - I replaced it. Checked the vent line that attaches to the sender that runs to the charc canister - seems fine.
I have pulled the sender unit from the trunk area and inspected in the tank a few times. I.m wondering about the plastic unit (think its called swirl unit) that sits above the screen. Does anyone know if there is a correct way (which way is front) for this to sit. Mine moved around and we put it back in roughly the same place then put the lid with the hole back on and put the sender down in.
I have completely drained the tank, fuel pump in fine, newish fuel filter etc. This only happens below half a tank on right turns.
any suggestions?
Old 06-29-2016, 10:01 AM
In the Fires of Hell.....
kdjones2000's Avatar
You need a new fuel strainer at the bottom of the tank, PN 928-201-081-04.
http://www.pelicanparts.com/catalog/SuperCat/1021/POR_1021_FULFUL_pg3.htm#item11
We just ran a 924S (early tank) out at Willow Springs and it only started sputtering 3/4 of a lap before it completely died. We didn't even make it back to our pits.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 06-29-2016, 10:07 AM
I need to replace the one in the 88 S I've gotten back to running condition. Not because it's stopped up, it's because the thing is busted. I was changing the fuel pump out and stuck a long screwdriver into to check for crap in the tank. I gently put it in there a few inches but never felt any resistance at the end. It's like someone has jammed a screw driver in there and knocked the thing apart. I was going to remove it but the threaded bung embedded in the tank wants to turn with it. I'm afraid I'm going to have to remove both items to get it out to replace. Gluing the threaded bung back into the plastic tank is going to be fun. What should I use for that. JB Weld?
Old 06-29-2016, 10:17 AM
Toofah King Bad
Rasta Monsta's Avatar
Perfect time to ditch the steel tank and go plastic.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 06-29-2016, 10:45 AM
i already have replaced the screen and the car has a newer plastic tank
Any other ideas?
Old 06-29-2016, 12:57 PM
Toofah King Bad
When my race car was doing that it "fixed itself". . .I figured it was a clog in the crossover tubes that allow fuel to go from the left to the right compartment in the tank, and that it cleared. The car used to do it with 3-4 gallons remaining, now it can run down to near dry without doing it.
Old 06-29-2016, 01:56 PM
por944s2's Avatar
This is probably why, on right turns your car has fuel delivery issues. With the top of the baffle no longer connected to the bowl, fuel can spill out and over the "bowl". Now if I cold only get a hand down the hole to re-attach the top.
Old 02-03-2018, 02:47 PM
I have this same issue on my track car -86 944 turbo.
What is that a picture of?^^
Old 02-04-2018, 06:54 AM
The whitish thing down at the bottom is the fuel strainer.
What he is saying is that there is an "upside down" bowl at the bottom of the plastic tanks that contains the fuel strainer and the final bit of fuel in the tank.
In this case, the top of that bowl has come off, allowing the fuel to escape the enclosure and let air into the strainer/fuel lines. This leads to cavitation, low fuel pressure and bogging down when coming off turns when your fuel level is low.
This is the first I have seen this, but it's a nice find - just hard to correct short of buying a new fuel tank.
Old 02-16-2018, 02:26 PM
Anybody else have this issue? I chased this all last year and short of driving around with a full tank all the time I'm not sure what else to do. I looked inside my tank but don't seem to have the same issue. What else could it be?
I've replaced the fuel pickup strainer but the old one was in fine condition so I doubt that it was causing the issue.
A friend suggested we stuff the tank full of fuel cell foam, I didn't know what to say to that...
The problem seems to start at approx. 5/8-3/4 full tank and under hard braking before a hard right turn. Obviously the fuel is sloshing away from the pickup screen, but why all of a sudden? What has changed inside the tank to cause this?
Thanks for any help you can provide.
Old 03-08-2018, 06:25 PM
Sounds like a different issue for you.
This one happens while at the end of a long right hand turn, or exiting that corner. Not on braking. It also tends to happen at around 1/2 a tank or less.
You may be losing some electrical connection while hard on the brakes... I doubt it is fuel, more electrical, possibly leading to fuel.
Old 03-08-2018, 07:53 PM
Yes, that's when it happens. When I brake hard, turn in and get back on the gas, it sputters in right hand turns. Doesn't happen with a full tank.
Old 03-15-2018, 02:44 PM
Comeau Racing
Had a similar issue in an 87 944 Spec car. Engine would cut out AFTER, not during, hard right hand turns. It was the ignition switch going bad and cutting power to the fuel pump while pulling the g's. Engine would cough and sputter when coming onto the next straight, then run like a raped ape. Fast.
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 04-01-2018, 05:16 PM
Comeau Racing
Cantrell, we epoxied the tank strainer sleeve back in and it's been fine for yrs.
PCA since 1985
Old 04-01-2018, 05:18 PM
Timmay!
How did you manage to get access to epoxy the strainer sleeve?
I have exactly the same problem with he bowl at the bottom of the tank having come loose.
Bill
Bill M
88 Carrera
86 BMW E30
86 944 SP1
Old 11-12-2019, 07:16 AM
Comeau Racing
Bill, I think the plastic bowl snaps into place?
RE: the epoxy deal. The threaded sleeve came out with the strainer. It just pulled out of the tank. We roughed up the inside of the tank sleeve hole. Then epoxyed the threaded sleeve back into place, then screwed the strainer back in.
PCA since 1985
Old 11-12-2019, 12:08 PM
Thanks, Timmay!
I plan to drain the tank and see if I can get the the plastic bowl back together and to stay in place. My strainer is pretty new but I will also take a look to make sure it's ok.
Bill
Bill M
88 Carrera
86 BMW E30
86 944 SP1
Old 11-13-2019, 10:06 AM
Comeau Racing
Here to serve the 944 community. I'm a smaller man, and as such, I can get much of my arm down inside the late model gas tank. Hope you can too.
PCA since 1985
Old 11-13-2019, 05:36 PM
I drained my tank today and took out the fuel level sender. When I looked in the tank the bowl pictured in the post above was just rolling around loose in my tank.
The top of my bowl was attached. But the bowl wasn't at the bottom of the tank where it should have the fuel pickup filter going in the side and the fuel level sender in the top. I tool out the fuel filter, re positioned the bowl with the filter and sender in their respective holes.
I'm optimistic this will solve the fuel starvation issue. I'll report after I get it on the track.
Bill M
88 Carrera
86 BMW E30
86 944 SP1
Old 11-15-2019, 05:36 PM
