Front Control Arm Bushings - Fitment Issues
I'm in the midst of rebuilding the aluminum control arms for my 86 944 N/A. Replacing the ball joints was surprising easy, but I'm in a real bind with the front bushings. I bought a set from ebay that looked more or less like the old bushings (rubber, with inner and outer sleeves).
When I pressed the bushings in, they're too long, leaving about a 1.5mm gap between the steel flange of sleeve and the face of the control arm. I can see inside the sleeves to see that the two sides are indeed touching. This seems like a fitment problem - clearing the webs of the crossmember upon installation and/or something that will screw up alignment later. Has anyone had this kind of problem with bushings? Is this normal? http://forums.pelicanparts.com/uploa...1468185436.jpg |
You need to cut the inner steel sleeve inside where the bushings goes with a hacksaw. Then they'll slide right in without issue, I'm assuming you bought these?
The steel lip needs to be flush with the aluminum arm. I botched a set.
Run a bolt through and use some washers so it loads the center of the new bushings. Tighten it until the rubber is compressed. Heat the arm quickly with a propane torch to see if they will pop in without destroying the rubber. |
Been there, not fun.
dermal tool if it won't come out. break it out like a stubborn oil seal. |
air tools....
looked at that link. curious as it looks like that replacement bushing does not have the 'inner steel sleeve'. dont have a pic of doing my front A arms, used delrin but now have a set of mono ball as delrin squeaks at times. but here is how I got the inner sleeve out of my rear arms when replacing them with mono ball. be careful. I caused a couple very small gouge places but they easily cleaned up with a file. http://forums.pelicanparts.com/uploa...1468243012.jpg |
Thanks for the advice everyone. Just to be clear, my problem isn't getting them out (already used the hacksaw method with the old bushings) -- my problem is that I have this gap between the flange of the new sleeves and the control arm.
The bushings came in this kit: I can see inside the center of the bushing and it looks like the two sides are making contact. I'll try the bolt trick but I don't think they're going anywhere. I suspect I'm going to have to take these out and start over again. Any recommendations on a good OEM-style bushing that fits? I live in the boonies on a dirt road, so I want to avoid a too-stiff ride. |
| All times are GMT -8. The time now is 07:54 PM. |
