-   -   fuse I.D. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/92220-fuse-i-d.html)
windwhisperer00 12-27-2002 11:30 AM
fuse I.D.
I was changing the lights on the fuel/temp gauge cluster on my '84 944 and when I hooked everything back up it didn't work, except of course for the lights. I connected everything back up the same way it came off. I'm thinking that I probably blew a fuse somewhere along the line. Underneath, where the fuse boxes are, there are 2 holders (to the best of my memory) -- an 8 holder and a 15 holder fuse box. The wiring diagrams are a bit confusing to read, so can someone tell me which fuse number (and on which box) is the fuel/temp gauge combo? Thanks.
SoCal Driver 12-27-2002 12:15 PM
Doesn't really jump out at you when you look through the tech articals on Pelicans main parts board but here:
http://www.pelicanparts.com/944/944QA/944_early_fuse_panel.htm
