Alexb944's Avatar
coolant flush
Is there a safe Coolant flush that you can use for the 85 944? like prestone cooling system flush?
Old 07-20-2016, 12:45 PM
They are all made for aluminum engines now. Flush away...
Old 07-20-2016, 01:14 PM
Alexb944's Avatar
Okiedoke.. thanks
Old 07-20-2016, 01:15 PM
Proprietoristicly Refined
John_AZ's Avatar
BUT---flush varies. I use half a can of Prestone HD flush--half.
If you flush with an entire can you will cause leaks at hose connections and other hidden areas.
The radiator has a rubber pressed seam.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-20-2016, 03:03 PM
Another option is to take the radiator to a professional radiator shop for backflushing instead of chemical flushing that could weaken your gaskets.
Old 07-20-2016, 04:50 PM
Alexb944's Avatar
im not sure if theres any reputable radiator shops here in knoxville...
Old 07-21-2016, 06:56 AM
Check the yellow pages. There is an old time one here that took my 944 automatic radiator, back flushed it with soda water and then recrimped the tanks. This removed deposits form the capillary tubes. Car ran cooler for sure.
Old 07-21-2016, 03:50 PM
