| Registered User |
				coolant flush
			Is there a safe Coolant flush that you can use for the 85 944? like prestone cooling system flush?
|  07-20-2016, 11:45 AM |
| Registered |
			They are all made for aluminum engines now.   Flush away...
|  07-20-2016, 12:14 PM |
| Registered User |
			Okiedoke.. thanks
|  07-20-2016, 12:15 PM |
| Proprietoristicly Refined Join Date: Jul 2001 Location: ~Carefree Highway~
			BUT---flush varies.  I use half a can of Prestone HD flush--half. If you flush with an entire can you will cause leaks at hose connections and other hidden areas. The radiator has a rubber pressed seam. J_AZ
				__________________ 1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) | ||
|  07-20-2016, 02:03 PM |
| Registered |
			Another option is to take the radiator to a professional radiator shop for backflushing   instead of chemical flushing that could weaken your gaskets.
|  07-20-2016, 03:50 PM |
| Registered User |
			im not sure if theres any reputable radiator shops here in knoxville...
|  07-21-2016, 05:56 AM |
| Registered |
			Check the yellow pages.  There is an old time one here that took my 944 automatic radiator, back flushed it with soda water and then recrimped the tanks.  This removed deposits form the capillary tubes.  Car ran cooler for sure.
|  07-21-2016, 02:50 PM |
