If it helps : Second Skin products on the rear deck
One of my longer term projects is rebuilding the rear deck carpet with soundproofing. First stages was to get some soundproofing. If you price out the Second Skin stuff, you find that 9 square feet is almost required, otherwise you are overpaying ... anyways, without further ado, here is 9 sq. ft. of Overkill Pro and Luxury Liner Pro just thrown in the back, for a rough size idea.
![]() the Overkill Pro is completely covered by the Luxury Liner Pro. It seems evident to me that, to rebuild the carpet with the same bulk, another sheet of Overkill Pro is required.
87 944 NA |
