Help. Sunroof
I am trying to close sunroof on my 88 924s. Problem is only 1 of the rear clips grabs & the other one doesn't.
They both operate up and down with the button but the pass side one isn't grabbing the roof piece.
How do I fix that? Thanks.
1988 Porsche 924S - On the road again after 3+ years.
Dodge GC ES 278,xxx and counting.
Old 08-14-2016, 07:53 AM
mhariush's Avatar
take it apart and look at the plastic gears. You probably need to replace them.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-14-2016, 10:59 AM
Thanks I hope it doesn't come to that. It is so darn close to catching. I once took apart a sunroof on an '85 Mercedes300D and never got it back together all the way, * and that was with the mercedesource manual.
I just saw your Ebay listing and looks like you may be helpful as I have this 88 924S put back together. I believe I will need a few odds n ends.
Austin
Old 08-14-2016, 08:18 PM
It's not difficult to replace the plastic gears, located at the roof (they drive the levers). Once you have done that adjust the motor clutch, located at the wheel well, so the gears will not strip again Clark's Garage has all this information.
We've all been there. Once you get it working perfectly, close it and never touch again. That way you will have the satisfaction of having fixed it and you will avoid the frustration of having to fix it again!!
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 08-15-2016, 08:07 AM
Send a message via Skype™ to massive
http://944foot2thefloor.blogspot.co.uk/2010/07/how-to-repair-sunroof-on-porsche-944.html
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 08-16-2016, 09:23 PM
