-   -   2.7L in 924S DME questions (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/926416-2-7l-924s-dme-questions.html)
The Glademister 08-22-2016 08:42 AM
Surprise, surprise! Turns out I've got a M44.11 engine in the '87 924S purchased recently. That's good news as I'm about to start preping the car for autocross. But it has the original 2.5L DME.
So how much of a difference would there be from a 2.5L DME to a 2.7L? Air/fuel mapping?
Can that be corrected with a simple chip change?
If I'm doing that... what if I upgrade injectors and FPR to 3 bar?
Performance modifications planned include exhaust, suspension, lightweight fly wheel and stripping the car down to about 1900 lbs.
Raceboy 08-22-2016 09:11 AM
I think you better want the 2.5 DME as it should have better ignition advance table. I could be wrong though but you could compare yourself.
The Glademister 08-22-2016 09:15 AM
Is that flashed onto the one chip that can be changed?
v2rocket_aka944 08-22-2016 10:30 AM
SHould be OK with the DME you have, make sure to run premium gas.
1987 would have had the 9.5 CR engine, right? Might have more advance than the 10.9:1 CR 2.7L wants.
Though the engines are so similar that I wouldn't worry too much about it.
The Glademister 08-22-2016 01:33 PM
87-88 M44.07-09 2.5L are 10.2:1 CR
89 M44.11-12 2.7L are 10.9:1 CR
v2rocket_aka944 08-22-2016 02:24 PM
Really? The 1987 924S got the HiPo engine before the 944?
Didn't know that.
If so...you should be OK with that DME
J1NX3D 08-22-2016 04:57 PM
IIRC the '86-'87 924S had the detuned engine. Also in '87 the 924S Le Mans/LE had the same tune as the 944. In 1988 all 924S and 8v 944 got the same tune 2.5L for all markets. The US tune just adds confusion for the pre-'88 cars.
I don't know off-hand if pre-'88 US spec 924S were also lower tune than RoW 924S, which were all lower tuner than 944's in their respective market.
The Glademister 08-22-2016 06:16 PM
I think the best course of action is to get a performance DME chip specifically for the 2.7L engine. That, coupled with turbo or 944S injectors and 3 bar FPR should make for really decent HP.
v2rocket_aka944 08-22-2016 08:20 PM
No need to change injectors, or raise FPR.
Stock NA ones are more than capable of supporting the power you are looking at.
Not to mention the 951 injectors are the wrong impedance for your NA DME.
petrolhead611 08-23-2016 01:52 AM
The very last few 924S models, certainly for Germany ,not sure about anywhere else, apparently had the 2.7L engine.
Rasta Monsta 08-23-2016 06:55 AM
No way. Literally.
Sent from my Nexus 6P using Tapatalk
The Glademister 08-23-2016 07:47 AM
Originally Posted by Rasta Monsta (Post 9251790)
No way. Literally.
Regarding...
The above poster saying very late 924S having 2.7L from the factory?
Or...
My $800 Craigslist 924S having a transplanted 2.7L?
Rasta Monsta 08-23-2016 09:10 AM
The former! As to the latter, there are plenty of interesting things that can find their way into a 924s...
v2rocket_aka944 08-23-2016 09:24 AM
I did see photos once upon a time of a 924S skinny body with the late 944 interior and 2.7L engine fitted.
Might have been production one-off?
Or maybe a 1989 944 with little fenders fitted :p
dgcantrell 08-23-2016 10:40 AM
If you look at the option code sticker inside the rear panel behind the carpet just over the spare tire, it will tell you what engine/trans combination came in the car from the factory. Being that 88 was the last year for the 924 series, I don't think they came from the factory with the 2.7's... But I'd take one in heartbeat.. LOL
J1NX3D 08-23-2016 04:45 PM
those were a limited run of pre-production 924S2's.
The Glademister 08-23-2016 06:42 PM
Photographic proof for any doubters...
http://i1336.photobucket.com/albums/...ps5vnekopd.jpg
J1NX3D 08-23-2016 09:18 PM
Nice! I'd definitely be picking someone did a transplant as no 924S came with the 2.7, especially anything as early as '87. I don't think it would be a 924S2 as those were 16v.
Porsche 924 S2 !
petrolhead611 08-24-2016 12:20 AM
The very few 2.7l engined 924S were sold in early '89. Porsche were probably using up parts they had too many of in a runout model. They also had a rubber? chin spoiler. Or so I read in a German online magazine about watercoolers.
The 924S2 mentioned in the French article were after market conversions using the 944S2 engine and Turbo brakes.
The Glademister 08-24-2016 09:47 AM
Porsche 924 S2 !
Agreed. This car came from a rural area so at some point the timing belt probably broke and the PO bought a salvage yard engine from a '89 944. Backyard mechanic drops it in never even knowing the difference.
Raceboy 08-25-2016 07:43 AM
Those were 924 S 2.7 prototypes. I happen to own one of those, sadly it is a race car. previous owner bought it from germany for cheap thinking that someone just converted to oval dash. But it was factory, with late gearbox, late flush sitting windscreen etc.
The prototypes were not sold to public, half of them were destroyed after it became apparent that 924 line will be discontinued and half of them were sold to employees.
The Glademister 08-25-2016 10:38 AM
Excellent information. Thanks for sharing!
petrolhead611 08-26-2016 01:30 AM
As a matter of interest, does the prototype 924S 2.7 still have the metal fuel tank? And the engine management unit under the steering column?
Raceboy 08-30-2016 10:51 AM
I got the prototype as a chassis but the DME location was in the passenger footwell. And gas tank was metal.
ernie9944 08-30-2016 05:01 PM
Yes.......http://forums.pelicanparts.com/uploa...1472605252.jpg
http://forums.pelicanparts.com/uploa...1472605271.jpg
dgcantrell 08-30-2016 05:37 PM
My wife would LOVE that thing. Hell, I would too. She's a purple fan.
Raceboy 08-30-2016 10:57 PM
That front bumper needs a bit of alignment :) But the interior photo is from another car (notice the 924 has flag mirrors and the interior photo car has passenger side aero mirror).
Raceboy 08-30-2016 10:59 PM
Here are photos of the DLS Automobile car interior: Porsche 924 S 2.7 Werks-Versuchsträger/ Prototyp! | DLS Automobile
petrolhead611 08-31-2016 01:50 AM
That sold car doesnt appear to have the front rubber valance spoiler. Also the wood trim inside is so out of keeping with the car.
ernie9944 08-31-2016 09:14 AM
Your rigth ,sorry I goof.The interior is off a 968.Here are the interior pics of the car.Apperently the wood simila was add by the actual owner.http://forums.pelicanparts.com/uploa...1472663546.jpg
http://forums.pelicanparts.com/uploa...1472663569.jpg
http://forums.pelicanparts.com/uploa...1472663595.jpg:D
ernie9944 08-31-2016 09:23 AM
Raceboy.... I just look at your pics after I send mine,it seem to be exactly de same car.But what I heard was that the wood trim were added after the car came out of Werks,don't know if it's true or not?:D
ernie9944 08-31-2016 09:46 AM
Here are two Euro successful attempt of S2 transplant in a 931 & 924:D http://forums.pelicanparts.com/uploa...1472665381.jpghttp://forums.pelicanparts.com/uploa...1472665444.jpg
