Removing window tint
Well, I'm working on the 88 S today and have removed the rear hatch to remove a tint job that is peeling off. Personally, I never cared for the stuff but.. Anyway, what is the best stuff to use to get the tint off and not mess up the defroster elements.. I'm seeing heat gun, ammonia, and hot soapy water. And, yes, I do know not to use a razor blade anywhere around the element lines. LOL
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 08-25-2016, 02:09 PM
Wipe it down with a good solvent like paint thinner or carb cleaner to dissolve the adhesive. Once it has dried gently use a plastic scraper.
Old 08-25-2016, 03:01 PM
I'll give that a try. I've been having some good luck with ammonia but it's taking a while. There are two layers of film on the glass....... grr.. I really hate this stuff.
Old 08-25-2016, 04:06 PM
Going faster all the time
Litesonic's Avatar
Steamer... can't say this enough.
It is only water (so make sure to have plenty of towels nearby. But doing it this way on past cars made me consider doing it as a sideline to make cash.
If you can't find a friend that has a clothes (or drapery) steamer... buying one is not that pricey.
http://www.target.com/p/my-little-steamer-go-mini/-/A-50037116?ref=tgt_adv_XS000000&AFID=google_pla_df&CPNG=PLA_Appliances+Shopping_Brand&adgroup=SC_Appliances&LID=700000001170770pgs&network=g&device=c&location=9028897&gclid=CjwKEAjwrvq9BRD5gLyrufTqg0YSJACcuF81FSpeBiHX 3aojKbo1MuQtLdZ36RKNoMiAQ0rk6d86SxoCZJrw_wcB&gclsrc=aw.ds
The obvious caution that steam can burn is in order (wear mittens, or some layer of protection).
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 08-25-2016, 04:10 PM
I might go this route if I have any difficulties. The first layer came off pretty easy. Got dark on me so I'll regroup tomorrow evening.
Old 08-25-2016, 05:32 PM
Mike80911's Avatar
As already said steamer is the way to go. That is what the pros use when removing.
89 930 Cab Black
11 Cayenne
Old 08-25-2016, 05:45 PM
mhariush's Avatar
Steamer sounds like a good way to go. I'll try that.
If you have the glass out, spraying it with paint stripper is very easy.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-25-2016, 06:18 PM
Science fact : steam - water that has reached 100degC and has entered the gas phase - is clear by eye. Water vapor - at a lower temperature than 100degC - is visible by eye. Clouds, fog, that wispy stuff above your food and coffee - water vapor, not steam... [checks Wikipedia article on steam]... ok maybe that stuff is called "wet steam".... but at any rate it is not above 100degC - if so, you'd get steam burns...
... anyways, the "steam cleaner" (BTW Harbor Freight has one for like $110 with the coupon) has specs with the temperature on it. Off the top of my head,theirs (McCullogh?) is like .. 135degF?... How's that compare with the others?
BTW thanks for this thread - always wondered how to get that stuff off...
Old 08-26-2016, 02:13 AM
Wouldn't paint stripper bother the defroster element adhesive?
Old 08-26-2016, 06:08 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
When I removed my tint, I left the hatch on, mixed 409 and ammonia in a spray bottle, cut a lawn and leaf bag to the approximate dimensions of the overall glass. Spray the entire inside of the glass with the spray bottle and then using a small roller or a squeegee, press the lawn and leaf bag onto the wetted area so it makes thorough contact. Close the hatch (in the sun) for about 15 to 20 minutes, depending on how powerful the sun is in your area. Then open the hatch and pick a corner that you can start from and SLOWLY peel the tint off in a parallel direction to the glass. It will amaze you how easy and completely this works.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-26-2016, 07:23 AM
Custom User Title
mikepellegrini's Avatar
+1 on the steamer. We just did one of my son's cars and it was pretty easy. Steam and peel. I managed to get the rear hatch off in about 6 pieces. You just have to be gentle and persistent.
The adhesive was tough. We tried Goof Off, Windex and a bunch of other stuff, then finally happened onto SuperClean cleaner. The glue came right off.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 08-26-2016, 11:57 AM
Actually water is working quite well at the moment. Since I have it out and laying upside down in the sun, the water can get nice and warm. I'm still having to scrape but it's coming off pretty well. I do have some Super Clean and though about breaking it out. I just might do that now. I'm going to pop the rear quarter windows out and strip those next. Those should be be a piece of cake. The messy ones are going to be the side windows...
Anyway, thanks for all the suggestions. I'll be looking at a steamer for future projects though.
Old 08-26-2016, 01:16 PM
mhariush's Avatar
Yes, water is probably the best way to go with the hatch. Steamer. Don't do paint stripper on it
Are you doing the full reseal while you're at it?
Old 08-26-2016, 06:12 PM
Actually, this one has not separated from the frame.... yet.. Probably won't mess with until it does.
However, now that I have the tint stripped, the protected coating on the defroster elements has come off with it. They are nice shiny aluminum. What should I use to re-coat them so they don't corrode?
Old 08-27-2016, 05:16 AM
mhariush's Avatar
there's an article out there about resealing the hatch and they talk about the coating for the defrost elements. But i'm sure a coat of Satin paint would do the trick.
Old 08-27-2016, 09:36 AM
That would probably be easy for the sides but those tiny elements going across the glass might be a bit trickier to paint. I might need to break out a fine liner brush.. LOL I'm thinking something clear though. Much easier to hide any mistakes.
Old 08-27-2016, 02:06 PM
