callmethewander's Avatar
just found my '44 in my neighbors driveway!
I had my car parked in 2nd gear in front of my house all weekend, I walked outside to see my neighbor's standing around my '87 turbo in their driveway! After several minutes I was able to determine that the starter had engaged by itself without the key in the ignition and cranked the car about 200' in second gear!!! What the Heck??? I'll never forget to put the parking brake on again. But how could that happen? I figured it out when I started the car to drive it back, the starter would not stop cranking even when I removed the key. I had to disconnect the battery. This could have been a LOT worse.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 09-05-2016, 10:33 AM
VW rabbits would do the same when the antena seal leaked onto the fuse box.
Old 09-05-2016, 10:36 AM
O so maybe the starter relay?
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-05-2016, 10:42 AM
The fuse/relay box is dry. I just pulled the ignition relay and the ignition relay X, reconnected the batt. and the car still starts and runs, however the problem of the starter cranking by itself has ceased, even when I reinstalled the relays, which don't really seem to have any effect on the starter circuit.
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-05-2016, 11:00 AM
I am sure they were happy to have a guest .
Old 09-05-2016, 11:25 AM
O yes, very. Thank God it rolled past their car parked in the street and stopped short of their two cars in the driveway, which is a bit of an incline!
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-05-2016, 11:43 AM
I would look at the ignition switch at the collum, starter harness and or the starter bendix/solenoid.
Old 09-05-2016, 04:18 PM
ok thanks. Is there no Starter relay? There doesn't seem to be. And what the heck do the ignition relays do?
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-05-2016, 07:12 PM
drift a 944's Avatar
Mine did something similar to this, it stayed cranking (although only when key was turned on) and continued to try and crank while the engine was running. Long story short, my case turned out to be a bad starter. I replaced the starter and the problem was solved.
I would however check your main battery cables, the one in particular which leads to the starter - make sure it's not grounding against the downpipe or something. And as mentioned above check your ignition switch... I have seen them fall apart and cause the car to crank on its own without key engaged. The plastic "plug side" of the ignition switch comes undone from the crimped on "metal side" of the switch, and the little mechanism inside falls and makes contact with the 'start' position tab. Something like that anyway.
- Elliott Grafton - 944Barn
Old 09-05-2016, 07:15 PM
Wow, interesting thx.
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-05-2016, 08:10 PM
tamathumper's Avatar
The primary cable from the alternator to the starter is most likely losing its insulation, along with the solenoid cable. On the 968 they run in the same sheath. Here's a link to my article on replacing mine.
http://www.968forums.com/topic/12460-replacing-the-alternatorstarter-cables-with-robby-cables
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-06-2016, 03:07 AM
curtisr
curtisr's Avatar
Yesterday I watched in horror as my 924s rolled out of the garage and smashed into my brand new Ram truck..!
I was in the process of moving cars around in the driveway and had removed the wheel chock without checking to see if the car was in gear or not. The 5 mph bumper mitigated additional damage but I'm sure I'm looking at a $1000 bill or more. It rolled out of the driveway and crossed the street on hunter-killer mode and hit the side of the truck.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 09-06-2016, 04:05 AM
Toofah King Bad
Rasta Monsta's Avatar
Wait, how did you determine the starter pushed it over there?
Sent from my Nexus 6P using Tapatalk
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-06-2016, 05:54 AM
Thanks Tamathumper that's great.
Rasta, two things; it was still in second gear and no longer moving, and when I started it to drive it back the starter engaged and wouldn't stop even after I removed the key. Also it's slightly uphill!
It stop just feet short of my neighbors two cars I think the battery gave out after moving it so far or the starter overheated and stopped.
1989 S2
1988 S
1987 944 n/a (sold)
Old 09-06-2016, 05:39 PM
