Wiring diagram issue for headlight switch
I am having problem with the wiring diagrams I have and online not matching either my wire color or the numbers on my headlight switch. I need this to rewire my switch 6 of the 10 wires were broken off at the base. Here are the numbers on the switch 56k,31,30b,5b,r,50 that I need wire colors for I have last for numbers with the wire color which is 75=green/grey, 58= 2 blue wires, x= Yellow/black and 7or L= blue black. the wire colors I don't know were they go are red, red/tan, yellow blue, brown, red/blue, and white black. any help would be greatly appreciated.
Old 06-11-2014, 10:52 PM
What year car & model?
Old 06-12-2014, 09:29 AM
It is a 87 944 base
Old 06-12-2014, 09:16 PM
TibetanT's Avatar
Hello There:
Here is the wire to pin colors for your Head Light switch. (First color is primary, second color listed will be the stripe on that wire.)
X = Black Yellow
56 = White Black
56K =Yellow Blue
31 = Brown (ground)
30 = Red
30b = Red Green
57 = Grey Green
58L = Grey Black
58R = Grey Red
58 = Grey Blue+ Grey Green
Hope this helps!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 06-13-2014, 10:36 AM
yes that helped greatly
thanks for your help
Old 06-13-2014, 10:11 PM
Dear Tiberan T,
Would you happen to have the same wire to pin colors for an 1984 944(non turbo)?Thank you
Old 09-04-2016, 06:01 AM
TibetanT's Avatar
Hello pvnano944:
Thanks for your message!
Here is the pin-out for the 1984 non-turbo 944 Headlight Switch:
X = Black Yellow
56 = White Black (small) White Black (Big)
56K = Grey
31 = Brown (ground)
30 = Red
30b = Red Green
58L = Grey Black + Grey Black
58R = Grey Red + Grey Red
58 = Grey Green
Hope this helps you with your car!
Ed Paquette
1983 911SC
1987 944S
Old 09-04-2016, 11:10 AM
Thank you!!!
Old 09-05-2016, 05:07 AM
Dear Tiberan T,
Sorry I trouble you one more time, but I was cross checking your pinouts vs my headlight switch and I have a few more, I have:
X
56
56K
31 = dont have it
30
30(2)
30b
58L
58R
58
58b
58a
Switch bulb
Please help if you can. Thank you!! If you send me your email I can send you a pic
Thank you!!
Old 09-05-2016, 06:10 PM
TibetanT's Avatar
Originally Posted by pvnano944 View Post
Dear Tiberan T,
X
56
56K
31 = dont have it
30
30(2)
30b
58L
58R
58
58b
58a
Switch bulb
Thank you!!
Hello again:
Sorry for the delay...just noticed this message.
You are correct that you have a few more pin-outs. The 58b and 58a I believe is really 56b and 56a, but take a close look so we are not making this worse.
However, with that said your MY 84 car will have 56b as a Yellow wire routed back to the Fuse Block D17. Your 56a wiring should be two (2) wires with one White wire going back to the Fuse Block G8 and a smaller Blue/White wire going to your Instrument Cluster for the High Beam/Low Beam indicator light.
Hope this helps, and Good Luck!
Ed Paquette
1983 911SC
1987 944S
Old 09-10-2016, 10:32 AM
Yes , it helped and my 944 has lights again. Now, do you know anything about assembling back the emergency brake next to the driver's seat? See, I disassembled the button, the spring inside, and one nut inside the tube and cant put it back together..help would be appreciated. thank you
Old 09-12-2016, 10:37 AM
