Tach Not working
Ok, so my tach USED to bounce when the battery was low, but has never worked.
Lately, I replaced BOTH of the crank/reference sensors. Now the needle doesn't event jump when the battery is low. I have tested the gauge itself and it does work. (tested by putting into another car!) Any suggestions? |
Wiser men than I will tell you to clean your grounds, grounds, grounds.
There will be a connection at the coil you can check. Lastly, it's easy to access the gauges whereupon you can clean the connections with deoxit. Gauges - Removing Late 944 (1985.5 and newer) Gauge Cluster |
Does the car run? If so, speed/ref sensors are fine.
The tach is driven by the DME. Check the wire going through a 4-pin connector between the DME and tach. |
I will check 4 pin connector at DME tomorrow - Thanks |
The gauges have been in, and out, a few times - especially when I recovered my dash. That's also when I checked the gauges on another car and found the tach worked, |
I gave up trying to find the wiring problem on my DE 951 tach. and rarely look at the tach with the shift light flashing telling me when to shift.
had this little tach intended for another purpose. http://forums.pelicanparts.com/uploa...1476020629.jpg |
My OCD I guess..... |
If you have scope, check the signal come out of DME #21 a green/black wire. It should be open most of the time with a grounding pulse when the coil is fires. Re-check this signal at the instrument-cluster connector to make sure that the wiring is OK in between.
| All times are GMT -8. The time now is 07:01 AM. |
