carolinus's Avatar
Strange idle...
My car has recently started to idle sort of strangely. When it is cold, it idles at 800 to 700, and is a little rough. When I use the gas pedal to bring it up to 900, it smooths out. It also gets a little better when the car warms up.
Should I monkey with the idle screw? Vacuum leak maybe?
What do you guys think?
Note: New spark plugs and wires, and some new vacuum lines in the fuel system.
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 01-07-2003, 11:06 AM
SoCal Driver's Avatar
Idle bypass/control valve. It's buried under the center of the intake manifold bolted to the block with a bent sheet metal bracket.
This is a blade or "knife" valve that is opened with a bimetallic spring and resistance heater element.
There are two larger diameter vacuum hoses going to and from it.
If you pull the electrical connection on it and check the pins on the valve you should see some resistance from the heating element. If you do then pull the top hose and squirt the heck out of it with carb cleaner followed by a penetrating spray.
If there is no resistance then the heating element has gone kaput and you need to replace it.
Note: The post 85.5 944's use a different designed valve. It is not interchangeable. The 944S's idle valve is different from the rest too!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-07-2003, 11:35 AM
carolinus's Avatar
Getting to it?
How do you recommend getting to it? Can you see it when you take off the intake boot?
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 01-07-2003, 11:40 AM
Further back. Between the center two runners from the plenum to the intake ports on the head.
Might have to take off the throttle body to get to it.
Old 01-07-2003, 12:23 PM
carolinus's Avatar
It just stopped....
It just stopped doing it. How strange. I will give that a shot if it acts up again.
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 01-07-2003, 03:28 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Re: It just stopped....
Prolly had some crap in a line or something. If you want to check you
AAV, Stick it in the freezer for a few hrs. look inside and there should be holage. Heat it Let it warm up and the hole will get smaller. If you get it hot, Hole go bye bye.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-07-2003, 08:52 PM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
SoCal - where is the S's idle valve and how do you adjust it? I heard the S doesn't have the infamous screw you can adjust on the N/A's.
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 01-08-2003, 07:45 AM
carolinus's Avatar
Back to it again...
It is doing it again... Also, next to the AAV but closer to the radiator there is a sensor or something with one wire coming off of it. Engine temp sensor? This sensor and its associated wire and connector is absolutely soaked in oil and stuff. If it is engine temp, that might be part of the problem, yes? (Note: Will clean anyway, but...)
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 01-08-2003, 07:59 AM
Re: Back to it again...
The single wire sensor is for the gauge as Wilk's states. There may be sufficient wire to clip it short and re solder it to the clip. Yes use the clip that is on the end of it as while this looks like just another slip-on it's not.
Try to remove the top vacuum hose to the valve and do the carb cleaner and penetrating oil thing. Helps about half the time. However as old as our cars are replacing the valve is the better choice even if removing the intake is necessary.
Old 01-08-2003, 12:18 PM
944S Boyeee
You have to jumper across two of the pins on the round test plug in the engine compartment to center the servo controlled idle bypass valve then adjust the idle at the throttle body.
Have to do a search on the subject to find out which of the two pins.
Old 01-08-2003, 12:22 PM
carolinus's Avatar
CURSING NOW!!!
Loud cursing now ensues! I decided to unplug the o2 sensor and determine if it needs replacement. The waterproof connector there broke right in half the second I tugged on it. I am now looking for the best options to replace it. Somebody said it was coaxial?
BMW 318iS 1991
BMW 325iS 1988
Quote of the week:
Old 01-09-2003, 11:21 AM
