Unhappy Heavy vibrations at higher speeds
Still trying to work out the kinks.... At speeds over about 40 MPH the wheel starts shaking pretty severly at both acceleration and deceleration. Any thoughts on this? I am thinking maybe tie rods and possibly loose suspension.
'83 944
Forest Green
Old 01-06-2003, 07:59 PM
SoCal Driver's Avatar
Most likely main a-arm bushings first then the tie rods and the ball joints. There is a u-joined linkage between the steering column and the steering rack that wears out too.
As you have an 83 with the steel a-arms the bushings and ball joints are easy to get to and replace. I would do the tie rods too and then get an alignment.
Don't take off the steering wheel if it's fairly straight right now as this is a good reference for keeping the steering rack centered during an alignment.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2003, 08:31 PM
adrian jaye's Avatar
I woulndt say over 40 is a higher speed !
but basics
1> check your tyre preassure (look at the inside of the petrol flap)
2> are the wheels mounted properly, check, your handbook, one of the five studs has a fleck of paint on it the wheel hole, with the valve closest goes on this stud, also the locking nuts MUST go on this stuid, make sure there the porsche ones and not others.
3> proper wheel alignment and balance, figures on 4 hours
hope this helps
been there done it , and got it fixed by using all of the above
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-07-2003, 10:44 AM
Wow, these cars are pretty particular on things like this eh? Thanks, I will give this a try.
'83 944
Forest Green
Old 01-07-2003, 10:57 AM
Almost as U-Nee-Que as the owners!!!
Have you replaced the timing belts yet?
Old 01-07-2003, 11:38 AM
Not yet, just found out that I need a $500 tool to replace it ....ugh.... Any idea if these are avaliable to rent anywhere?
'83 944
Forest Green
Old 01-07-2003, 12:27 PM
You don't need the tool to replace the belt. Chances are you may get the tension too tight as the tensioner/idler will move when you tighten the retaining nut. The 90 degree twist will get you close enuff regardless of what others say. Best to leave it a bit loose than too tight.
Even if it's too tight it's better than having a belt break in the next week or so because you didn't replace it. Figure about $1300 to have the head rebuilt and installed.
Old 01-07-2003, 12:37 PM
True enough But all is well. I found someone I know with the tentioner tool, so I will probably put on a new one in the next day or two and tighten it with your specs and then retention with the tool.
Thanks agian for all your help
'83 944
Forest Green
Old 01-07-2003, 02:26 PM
