onrails's Avatar
Send a message via Yahoo to onrails
Heater core
Looks like my heater core sprung a leak. Got some drops on the housing under the glovebox. Any ideas about the fix? I've not been able to locate one. Can they be repaired by a radiator shop? How many variations of this core are there. Dont want to pull it to match it up. I still drive it year round, 10 mi a day. It's fun in the winter lol. Any suggestions.
By the way my last issue with hesitation was the coil wire. Thank you
Old 12-15-2016, 07:37 PM
What year car?
Either way one of our several 944 parts folks should be able to help you out.
A leaking heater core in a 944 is a *very* rare occurrence...so a good used part should do you just fine.
Check with these Pelican users (off top of my head):
gravesjeg
kens_74_911s
JoshB
lart951
Old 12-16-2016, 08:10 AM
I remember reading something on Clark's about heater cores. Something to the effect of that the heater core was suspended in the air and the car was built around it. That they are very difficult to remove. And that stop leak might be a better idea
Old 12-16-2016, 10:02 AM
onrails's Avatar
It an 87 S. So I've been thinking about this and no one even lists the heater core in St. Louis. I can believe it's a part that never left the shelves. I wouldn't stock it either. Another thing is I don't smell or see antifreeze on the inside of windshield. The mix is good to -20 so it's not too diluted to be detected. The green drops I see are on one of the flex tubes( I believe it goes to the glove box) could the problem be in the way I saw the hoses are attached with "clips". I'm starting to think the leak is not in the air path. I'm gonna just have to tear it down this wknd and look.
Old 12-16-2016, 10:15 AM
Toofah King Bad
Rasta Monsta's Avatar
Cheap new, and a PITA to swap. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-16-2016, 10:23 AM
The leak could be from a loose hose clamp on the outside and it's praying in and dripping down on the inside
Old 12-16-2016, 11:06 AM
FRporsche's Avatar
The heater core is pretty easy to change. You just have to remove the glove box and some air ducts. There's a DIY on RL 968 forum.
'87 951 | '87 951 | '87 944 | '93 968 | '84 944 | '82 911
'82 300TD | '77 6.9
Old 12-21-2016, 02:53 AM
