WTB: Rear main seal install tool
Any one want to get rid of their RMS p234 oil seal install tool?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Location: In a dumpster behind Albertson's in Los Angeles County
Take the RMS to Home Depot, and match it up with a PVC pipe cap of the same outside diameter. Search the forum, there is a posting for an RMS install tool made from one. Or, you can always do it the old school and equally reliable way, remove the old RMS, set the new RMS in place, put the old seal on top of it (outside of seal to outside of seal....that's the side with the part number on it) and lightly tap around the old seal until the new one seats. That's how I install them..no leaks
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
AFM #725
^ great idea... Save a ton of money
Thanks guys. I work on a lot of cars so it may be worth the money. Just a little thin here at the end of summer.
1982 911 SC 3.0L |
How hard is it to get to the RMS? I'm getting ready to do all front seals and time belt and balance shaft belt and I know the FMS is a pain in the ass to get to. Was just wondering if its the same with the rear and if I should do it at the same time.
Sent from my SCH-M828C using Tapatalk 2 |
AFM #725
It's similar to a clutch job
That Guy
I have the factory RMS tool i rent / loan out if anyone is interested. Original poster already contacted me about it, this offer is open to anyone. Tool is currently in PA, but pretty sure they are done with it.
RMS install tool P234 rental offer RMS replacement is a clutch job.. basically the last diassembly step and the first step in reassembly. The PVC method and using the old seal method all work, but this is the fool proof way.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 09-01-2012 at 09:21 AM.. |
Just as easy as a clutch job.
944 addict
Once the flywheel is pulled, drill a small hole in the seal (being careful not to touch the outer portion where it touches the flywheel or the crankshaft). Take a sheetrock screw and screw it into the bearing and pull the bearing out with a pair of pliers. I installed my seal with a PVC fitting. Remember to oil the inner part of the seal before you reinstall it or it will scorch it.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
to extract the sealfile down 16mm dowel to 15mm so its slip fit into central hole of rms, then stuff hole with plasticine.hammer dowel into hole and out will pop the bearing.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
sorry, meant to extract pilot bearing, not rms
plays with toy cars
Bumpity bump. Anyone have a P234 tool they want to sell, second hand? Not interested in a DIY tool after doing research on success rates.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
Use the old rms to seat the new rms. Been doing it for years. No issues. Clean the bore with 600-800 grit sand paper.
Never give up |
